TSP 408 Alternator Bracket
Old 09-02-2012, 02:24 PM
sasquatch's Avatar
Default TSP 408 Alternator Bracket
I have a TSP 408 block and I am using the acessories off my LS1 but the alternator doesn't seem to bolt up. Do i have to use a different bracket system or another alternator? Or does the alternator get relocated? Thanks for any help.
Old 09-02-2012, 06:23 PM
backdraft408's Avatar
If its going into a fbody then it will bolt right up. on my tsp block my 408 lq9 block didnt have but one bolt hole on the front of the block for the alternator. i had to drill and tap another for the alternator.
Old 09-02-2012, 06:30 PM
Sales1@Texas-speed's Avatar
^Agreed with the iron blocks they didnt have the extra threaded hole that the original LS1 blocks had. It will be no problem guys have been making this work for years.
Old 09-02-2012, 06:46 PM
ws602's Avatar
Don't use that bottom bolt it will be ok without it..
Old 09-03-2012, 02:46 PM
sasquatch's Avatar
Thanks guys for the info.
Old 09-19-2012, 08:47 AM
Canada's Avatar
How deep should you tap it and what is the pitch size? You figure this would be done since they are a machine shop and know that this is a common problem, plus they ask what its going in. Anyone here tap the block for the 2nd hole? Any advice or info on how to do it?
Old 09-19-2012, 09:30 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Let's clarify the mystical iron block alternator situation, because I feel like most who preach about it on the internet have never seen the block in person.
Here's a picture of the aluminum block bolt holes. The green holes can be used on the new iron block you have, the red will disappear and not be used, period.
Here's the iron block, with the bolt locations highlighted for easy comprehension.
So you have the bottom green hole already. The red bolt hole location cannot be used on the iron block without catastrophic failure. The upper green bolt hole is the one that can be drilled/tapped for use. There is plenty of meet there for you to drill and tap so that you will have two bolts holding the bracket on the front side, and then of course you have the one bolt holding the bracket on the back side of the alternator.
Can you use just the lower hole and the rear bolt? Of course! people have been doing so for years! Would I drill and tap it and run three bolts total?? Absolutely!
Hope that helps clarify what you're dealing with!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-19-2012, 10:13 AM
sasquatch's Avatar
Thanks Matt for the illustrations. Can you give the specs on what tap to use? drill bit? Depth? Thanks
Old 09-19-2012, 10:17 AM
Prorac1's Avatar
IIRC, the tap size is 10X1.5 thread. Max drill depth is around 30mm, and max tap depth is 17mm. Hope this helps, Eric L
Old 09-19-2012, 10:30 AM
That is what I show as well. I show from the factory it has 2X of those bolts at 125mm long, and one of them at 90mm long. My book does not say which that top hole was though, unfortunately. You could likely tell by looking at the bracket and seeing which two are the same thickness, and the other will likely be thinner (on the bracket where the bolt passes through).
__________________
Old 09-24-2012, 04:57 PM
Canada's Avatar
Going to have my cousins machine shop do this while she mills my timing cover down for me. So I just need her to use a 10X1.5 thread tap. Drill 30mm where the top green dot shows and then tap it 17mm deep. Is this all correct?
Old 09-24-2012, 05:06 PM
We typically use the bracket for a jig to ensure we drill it in the right location!
__________________
Old 09-24-2012, 05:19 PM
Canada's Avatar
Ya I planned on that, want to make sure its perfect so nothing can come back on me. I asked for you guys to do that to mine but it was never done. Same thing with my timing cover. Are you the one dealing with the UPS mess up, think Aaron said he was waiting to hear back from Matt about that situation.
Old 09-24-2012, 05:35 PM
Sending you a PM!
__________________
Old 09-28-2012, 02:43 AM
Canada's Avatar
Got it and sent one back with all the info I was told from UPS. Thanks for the drawing and the tapping info. My cousin will be doing that this weekend for me. She is still milling down the timing cover. So far I've got a weeks worth of an hour here and there into it each day and then she has two days in it working on problem areas. That elderbrock 2 piece cover sure does take a lot of work to work with a double roller. Still not sure if I'll have to have her make a spacer for that sensor as it might hit on the raised part of the timing chain sproket where it has that raised up groove half way around it on the inside. If it does hit and I have a spacer made for it, will that effect the way the sensor on the timing cover reads?
Old 09-28-2012, 09:21 AM
As long as you have the proper sensor to reluctor clearance, it should not be any issue. I don't remember that spec right off hand, but can find it if you don't have it. Still working with UPS to see if anybody can help!
__________________
Old 10-02-2012, 12:46 PM
Canada's Avatar
If you can find that for me I'd appreciate it. I finally got that cover clearances to fit and ready another place that someone mentioned it wouldn't work. If I can get the specs and measure it, I can then have a spacer made if needed to fix the problem. Those Edelbrock timing covers are a joke being called bolt on. Thanks for all the help with the specs. Got the block drilled for the alternator bracket so I can now have two bolts up front and one in the back to support it. Fell better only missing one spot to attach it to than missing two spots.
Quick Reply: TSP 408 Alternator Bracket
