Build help
Old 05-20-2013, 01:55 PM
Crowhater's Avatar
Default Build help
Several weeks ago I pulled my LS3 416 apart to do a cam swap and found damage. After going all the way into the engine I decided to just replace it with a new short block because #7 piston skirt had rubbed the cylinder wall. The crank and rods are ok but it wasjust easier to buy a new short block.
So here is what I have going on with the new build so far. Please let me know if you have any advise or suggestions. I will be assemblind the engine at the end of the week and install it is the car this weekend.
specs:
2008 C6 Corvette A6 coupe
ERL dry sleeve 427Ci LS3
SDPC cylinder heads SD8802-1
.660 Brian Tooly springs
Manley SS valves, 216.5 intake 160 exhaust
Flow 351 intake & 228 exhaust at 600 lift
70cc chamber
cam shaft 238/248 .629 113lsa
Fast 102 intake
American Racing headers 1 7/8 & X-pipe. The headers are coated with 3000* PolyDyn heat coating.
Magnaflow mufflers and electronic cutouts in front of the mufflers.
60# injectors
Haltech cold air intake
25% underdrive pulley system
TR6 spark plugs
factory rockers with the needle bearing upgrade
Comp Magnum push rods.
Katech timing chain
LS7 lifters
Callies crank & rods, weisco pistons, ARP bolts all the way around
Dewitts over size radiator and dual fans.
Dual B&M trans coolers with fans and therm control
Changed the rear gear from 2.73 to the Z06 3.42
Trans brace
Pfadt polly trans mount
Hennesy polly engine mounts
160* thermastate
Elite oil catch can
Century Transmission 6L80
Circle D tripple disc 3800rpm stall
here is my cam card
Old 05-20-2013, 02:36 PM
TNSS's Avatar
looks like a pretty solid build. i would love to see a set of the new TFS 255 ls3 heads on this motor
Old 05-20-2013, 04:13 PM
Crowhater's Avatar
So would I but I was not planning this engine purchase so I dont have the extra cash to spend on those heads right now. I tried to sell my heads to offset buying some new ones for this but I dont have the time to wait around for my heads to sell. The heads I was looking at are the Texas Speed 260 LS3.
Old 05-20-2013, 04:41 PM
litle88's Avatar
Alot of similar parts like mine lol, you have a solid build again! Looks good but tell me more about the piston problems you had please. Got any pics?
Old 05-20-2013, 05:05 PM
Crowhater's Avatar
It pretty much speaks for its self.
Old 05-20-2013, 06:28 PM
litle88's Avatar
Damn bud that's pretty much the entire bore! Bad rings? Debri? Tune?
We're they coated?
That's awful, glad you got a bigger and better build for sure though!
Old 05-20-2013, 06:36 PM
Crowhater's Avatar
We're they coated?
Yes they where coated Manley forged pistons. I bought this short block from a company that is now out of business and it was a bad build job. The rig gap was 35 top 40 second, and that is big even for an extreme nitrous build. From the looks of the cylinders they took a factory block and did a dingle ball hone then just assembled a stroker kit. At the time I was in a hurry because I just scattered the factory engine and the car had 1800 miles on the odo and the warranty was voided because of modifications. Lesson learned I will never do that again.
Old 05-20-2013, 10:09 PM
Realcanuk's Avatar
Nice build list there. I just went through this as you know and have a lot of similar parts. The one thing I'd do different is go to link bar lifters, but I know many use LS7 lifters with no issues.
I hope all goes as smooth for you as it did for me.
Old 05-20-2013, 11:14 PM
TNSS's Avatar
I just sold my cnc 243 heads on racingjunk in 4 days. its worth a try. I know what its like to try to off set the cost I sell everything LOL.
Old 05-21-2013, 08:41 AM
Crowhater's Avatar
I dont really want to rush when it comes to heads. Changing out cylinder heads is not a very hard job so I would rather wait until I either find a deal or get some really good heads.
Old 05-21-2013, 02:31 PM
Pfadt Racing's Avatar
Looks like a solid build! I've been throwing the cam plates on my motors lately because I had some bolts back out once. Other than that looks awesome, be sure to post some vids up when its done..... the only thing I would say is try our headers
Old 05-21-2013, 07:09 PM
Blackpanther99's Avatar
Nice list! Sounds like its gonna be a great turnout for you this time
Old 05-21-2013, 10:01 PM
Realcanuk's Avatar
Definitly spend at least the 10 bucks for a cam bolt retainer....
Old 05-21-2013, 10:17 PM
litle88's Avatar
Lol what the hell? ^^^ canuc where's that from? Lol
My 20 bux well spent with a lil blue loctite lol
Old 05-21-2013, 10:21 PM
Realcanuk's Avatar
My friend. How many times have I read of guys swearing they used locktite, torqued the bolts, and they backed out.
I just did an LS402 build. I used locktite, torqued the bolts, and blew my build budget right out by 8 dollars by adding that retainer. It is a comp part, available almost anywhere.
I wonder why comp makes and sells it ???
Old 05-21-2013, 10:32 PM
Realcanuk's Avatar
Just wanted to add.. that was a lot of LOL you did there. I am sure your bolts will stay put, but are you wondering why you didnt use one of those ?
LOL
Old 05-22-2013, 02:14 PM
TNSS's Avatar
should this cam plate be used on all builds? or do the ls2 or 5.3 not have this issue? I have never used one of these but I have recently seen a few guys having problems with cam bolts backing out.
Old 05-22-2013, 02:29 PM
litle88's Avatar
LOL
No I was not being sarcastic I was just trying to see what was in the pic, I thought you were talking about some build where someone used ACE hardware bolts cause that what it looked like at first lol. I didn't even see the retainer plate! Hell I didn't even know they existed! Thanks for the heads up man.
Old 05-22-2013, 03:12 PM
TNSS's Avatar
is there a part number for this retainer plat?
Old 05-22-2013, 08:13 PM
Realcanuk's Avatar
Don't Blow the budget... Lol. 2.95 !
http://www.jegs.com/i/Comp-Cams/249/4605/10002/-1
Quick Reply: Build help
