LS3 vs L92 Valves, side by side comparison
Old 01-12-2009, 10:33 PM
SweetS10V8's Avatar
Default LS3 vs L92 Valves, side by side comparison
I got my new GM LS3 hollow stem intake valves today from the dealership (#12569427).
I was only expecting them to the exact same valve but with a hollow stem to make them lighter, but I was wrong. They look much more finished than the stock L92 valves. They are fully machined on the top of the head and on the bottom side as well, where the L92 piece looks cast. So if your looking at complete cylinder heads on ebay or something and are wondering if they have the hollow stem valves or not, check out the bottom of the valve for a possible give a way.
I had to weight them for myself even though I had seen posted weights in other threads. I saw a 19g difference between the two.
Old 01-12-2009, 10:55 PM
405HP_Z06's Avatar
Great info
Old 01-13-2009, 10:22 AM
Bandit28's Avatar
Are those only the intake valves? or did you get all 16 for $200
Old 01-13-2009, 07:05 PM
SweetS10V8's Avatar
Just the eight intakes. $22/each +tax.
Old 01-13-2009, 07:19 PM
offaxis's Avatar
Were the exhaust valves hollow on the ls3 head? or were they the same
Old 01-14-2009, 07:03 AM
1.8t's Avatar
The exhaust valves are not hollow on the LS3.
Old 02-13-2009, 09:14 PM
SweetS10V8's Avatar
The LS6 exhaust valves were sodium filled from what I recall, but not the L92/LS3 stuff.
Old 05-25-2010, 10:11 PM
Silvy6.0's Avatar
Sorry to bring up and old thread but could you just swap out the intake valves if you have a set of L92 heads? Just wondering. Again, sorry for bringing up an old thread.
Old 05-25-2010, 10:12 PM
Silvy6.0's Avatar
Also, what are the casting numbers on the LS3 heads?
Old 05-26-2010, 10:44 AM
cam
cam's Avatar
I think there's a few variants of the L92 valve in terms of finish iirc. Regardless great post and you should add this info into the sticky here
https://ls1tech.com/forums/generatio...-l92-info.html
Old 05-26-2010, 10:53 AM
bearcatt's Avatar
Are the LS3 valves longer than the L92 valves ?
Old 12-06-2010, 12:09 PM
The stunningman's Avatar
I just asked pretty much the same question.
https://ls1tech.com/forums/generatio...-question.html
So basically you guys running the LS3 heads are having to use different length pushrods intake and exhaust?
Quick Reply: LS3 vs L92 Valves, side by side comparison
