ls1 vs ls7 map sensor
Old 03-22-2009, 12:49 PM
red02Hawk's Avatar
Default ls1 vs ls7 map sensor
ok i picked up one of my copies of gmhtp the other day and i noticed an article where they swapped a gen IV crate motor in a 2001 z28. They didn't use the the map sensor on the front of the intake, instead they used the vacuum port on the rear of the intake. My question is if the computer is getting a full overhaul tune anyways, cant i use the map sensor at the front of the intake and just adjust the values??
Old 03-23-2009, 08:00 AM
sroach20's Avatar
it would be fine, i had to move mine to the front and retune.
Old 03-23-2009, 06:31 PM
fbam's Avatar
Why do you need to retune? What would be the result if you didn't retune?
Old 03-23-2009, 06:34 PM
sroach20's Avatar
dont know if it makes a difference front or back. i had to redo mine because i went from a stock lq4 to an l92/ls3 setup.
Old 03-23-2009, 08:16 PM
Mike454SS's Avatar
You need to re-tune the engine because it's a different engine...they're both 1-bar MAP sensors...their calibration is the same.
Old 03-23-2009, 08:27 PM
red02Hawk's Avatar
ok, so the census here is that its the same MAP sensor, i mean it does have the same part# on it, but it is in a different location so the values it will read will be different than if it were located in the back of the intake? Just trying to figure out why GMHTP would go through all the trouble to put another sensor on the rear of the intake when you have a perfectly good one on the front.
Old 03-23-2009, 08:35 PM
sroach20's Avatar
you have the same map, the ls3 uses the different one.
Old 03-23-2009, 09:23 PM
fbam's Avatar
OK, so am I an idiot for using sensor safe silicone and putting my ls1 map sensor in the front of the manifold?
Old 03-23-2009, 11:07 PM
sroach20's Avatar
which intake did you use, ls3 or l76?
Old 03-24-2009, 05:16 AM
fbam's Avatar
I have an ls3 manifold. The sensor almost fit but not quite, so I used some silicone to ensure it wouldn't leak...at least I hope it wont.
Old 03-24-2009, 08:12 AM
sroach20's Avatar
do like i did this: get an ls3 map sensor and pigtail from the dealer, you can get a 5mm bolt from lowes or home depot to hold it down. the only difference in the wiring is for the outer wires, they just swap around and the center one stays put.
https://ls1tech.com/forums/generatio...ap-sensor.html
Quick Reply: ls1 vs ls7 map sensor
