0821 head castings?
Old 04-09-2009, 09:01 AM
StrokerLS1's Avatar
Default 0821 head castings?
I found some 0821 casting heads for fairly cheap. Are these the same as L92 heads? Are they the heads that came off a LS3? Im looking to put them on my 408ci. Thanks
Old 04-09-2009, 09:12 AM
69LT1Bird's Avatar
821 is from the LS3. L92 and LS3 have the same port shape and combustion chamber sizes. The 821 should have the lighter valves. Originally GM used a different casting process for the Corvette heads which produced smoother ports.
Old 04-09-2009, 09:23 AM
StrokerLS1's Avatar
Cool so these should be exactly what im looking for. Thanks. It looks like they came with yellow valve springs like the ones that came off the c5 z06. I wonder if they are the same ones
Old 04-09-2009, 09:31 AM
69LT1Bird's Avatar
I think they are.
Old 04-09-2009, 09:35 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
They are what you are looking for, they are L92 heads. Casting number doesn't necessarily indicate what valves are in a new head though. I currently have L92 castings on sale CHEAP for $630 for a set of complete heads.
Jesse
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 04-09-2009, 10:42 AM
StrokerLS1's Avatar
Originally Posted by Scoggin Dickey
They are what you are looking for, they are L92 heads. Casting number doesn't indicate what valves are in a new head though. I currently have 821 castings on sale CHEAP for $630 for a set of complete heads.
Jesse
if the ones im looking at fall through then im giving you a call. thats cheap! what is the most that can be milled off these heads. my 408 has -28cc pistons in it. i had a blower installed but sold it. im just trying to get as much compression and power out of it without changing the pistons. Thanks
Old 04-09-2009, 12:23 PM
1CAMWNDR's Avatar
The L92 has a 70-71cc combustion chamber. You would need to mill quite a bit to recover compression from a -28cc dish.
Old 04-09-2009, 01:09 PM
StrokerLS1's Avatar
yeah i know it is going to need to be quite a bit of milling. i just dont want to mill so much to where i compromise the head strengh. im guessing somewhere around .045 .050 with .042in head gaskets? i know it wont get me stock comp but hopefully somewhere around 9.5-10.0 i would hope.
Old 04-10-2009, 05:40 PM
Tigman's Avatar
Default 821 Castings?
How do they rate compared to the famed 823's?
Old 04-10-2009, 05:46 PM
Ok, actually casting number can tell you which head it was originally on a stock head. 821s were LS3, the difference between the casting numbers is the valve seat between LS3 and L92. You're not going to have a performance or flow difference based on the casting number, it really is not relevant
__________________
Old 04-12-2009, 11:06 PM
patdown's Avatar
So if the 0821 heads have the yellowish springs and a shiny intake valve, is that an L92 or LS3 head?
Old 04-12-2009, 11:11 PM
SweetS10V8's Avatar
The difference between an L92 and LS3 head are the valves and springs. The valves are what really matter because you have to match your springs to your cam anyways...
https://ls1tech.com/forums/generatio...omparison.html
Which valve is in the heads your looking at?
Old 04-13-2009, 08:26 AM
Hey, is this Pat Downey? Glad to see you received your heads. I'm going to send you a pm.
You've got LS3 heads.
-Jesse
__________________
Old 04-13-2009, 11:52 AM
patdown's Avatar
That's me, Jesse. Thanks for clarifying which heads I received. These heads obviously have the valve on the right in SweetSV10V8's link.
I got the long end of the stick for a change.
Old 06-04-2012, 04:23 AM
dmc1400's Avatar
Default 821 heads
maybe a dumb question but..... will 821 heads fit a 2000 ls1? any performance increase from that? if they do fit is it a straight up bolt on deal?
thanks in advance
dave,
Old 06-04-2012, 05:38 AM
litle88's Avatar
thanks in advance
dave,
Lol noob bringing it from the 3yr old death, no sir you CANNOT use Ls3/L92/L99 heads on an Ls1 because you need a minimum bore size of 4.0 in.
The following users liked this post:
Stefan N (03-26-2023)
Old 06-04-2012, 08:06 AM
bww3588's Avatar
Easy asshat...at least he didn't start a new thread.
Old 06-04-2012, 05:01 PM
litle88's Avatar
Lol YOU CLOWN! Hows it coming bud?
Quick Reply: 0821 head castings?
