L92 on a LS7 block
Old 07-19-2009, 06:49 AM
LSXHawk's Avatar
Default LS7 in a 2wd blazer with Ported WCCH L92
Ok here is the setup. My buddy has a 2wd s-10 blazer with a ls7 in it with WCCH ported L92. With driver in the vehicle it weighs about 3750.
The LS7 bottom end is stock beside the ARP main stud kit, WCCH poted L92, GM Carb Style intake with a edlebrock elbow, ported 90mm throttle body, LSR off the shelf comp cams, slp under drive pulley, Stock rockers, 4000 stall, powerglide with trans brake( Yes we know he needs a 350 turbo), 4.10 gears(soon to be 4.56gears), TSP mail tune(which I have tweeked a little but not much), TSP 100mm MAF, 60lbs injectors, GM LS2 stand alone computer and harness, and finally BRP 1 7/8 headers steeped to 2 inch.
First time at the track it was running in the mid to low 11s on a hot and humid day. After playin with the tune and changing the injectors we got it to hit a 10.86@126mph in the quarter. Our goal is to get it into the mid to low 10s so hopefully with some more tuning, gear swap, and some weight reduction we can get it. Ill post up the time slips later and also some pics.
Old 07-19-2009, 02:27 PM
philntx's Avatar
Post up your build details and pics here: http://www.s10forum.com/forum/lsx-discussion/
Old 07-20-2009, 06:27 AM
tektrans's Avatar
Sounds Like you've got a runner there! Nice job so far!!
I have L92's on top of my LS7 as well.
Old 07-20-2009, 08:14 AM
LSXHawk's Avatar
U definately got a runner. I read ur article in GMhightech and I was very impressed seeing u were running the stock l76 or ls3 intake.
Old 07-20-2009, 05:27 PM
LSXHawk's Avatar
Some pics
Attached Thumbnails L92 on a LS7 block-picture-001.jpg   L92 on a LS7 block-picture-002.jpg   L92 on a LS7 block-picture-003.jpg   L92 on a LS7 block-picture-004.jpg   L92 on a LS7 block-picture-005.jpg
Old 07-20-2009, 05:40 PM
tektrans's Avatar
Thanks bro',
That truck is SICK!!!!!! I love it!!
Old 07-20-2009, 06:05 PM
LSXHawk's Avatar
Thanks bro',
thanks, my buddy has a small salvage yard and this vehicle here was put together with parts he had laying around. He calls it the junkyard dog which is a perfect name for it. It started out with a LT1 and the he had a ATI F1 on it which went 9.70 in the quarter. Now we have the NA stock bottom end LS7 in it with the L92. Were definately on a budget and we want to hit low 10s on pump gas.
Old 08-29-2009, 03:11 PM
LSXHawk's Avatar
Update. This setup just went 10.41@130mph at michigan today. Hopefully when the becksheet metal intake arrive and the yella terra's we will get it to the low tens.
Old 08-30-2009, 11:52 PM
68 RS Convertible's Avatar
Wow, thought you said you were on a budget!!! Wish my budget was more like your's!!! That thing is sick!!! Does that thing get run on the street as well? Talk about a sleeper!!!!
Old 08-31-2009, 08:33 PM
LSXHawk's Avatar
yes it does it has working light, turn signal and power windows
Old 09-01-2009, 07:24 PM
Rock_Daddy's Avatar
Hey are you the guy I was talking to at Milan this weekend? I have the purple LS Vega.
Old 09-02-2009, 06:11 AM
LSXHawk's Avatar
u werent talkin to me but u were talkin to the owner of the blazer. Ur the guy who has the ls3 correct?
Old 09-02-2009, 06:35 AM
tektrans's Avatar
Coming along very well. Impressive.
Stock cubes at that weight and pump gas, Glide, 10.4's is a killer time!!
Old 09-02-2009, 06:45 AM
Rock_Daddy's Avatar
Yep. Sometimes I call it and LS3 but its a L92 with all the VVT stuff removed so its like one. I kind of use the terms interchangeably as some don't know what the L92 is but do know the LS3. It was in a 72 Vega running 9.5's I was impressed that 3800 lb dog was moving out like it was.
Old 09-03-2009, 09:13 PM
LSXHawk's Avatar
Pics from Michigan this was his 1.49 60ft launch.
http://www.photoreflect.com/pr3/orde...HS030061&po=61
Old 11-07-2010, 06:54 AM
LSXHawk's Avatar
New best 10.15@129mph. big thanks goes out to jermey at fasterproms for making it faster and he was also right about the caddy lifters. that 10.15 pass was done on 4 lifters heading south.
Old 11-07-2010, 08:03 AM
Rock_Daddy's Avatar
You got that brick moving pretty good this year.
Old 11-07-2010, 06:28 PM
LSXHawk's Avatar
yes it is and its ashame that i wasnt able to change the lifters because I know he would have hit 9s. Also this was all done off idle no trans brake at all.
Quick Reply: L92 on a LS7 block
