MAF help
MAF help
This is the system I want to run on my LS376/480 GTM project. Problem is, there is only one MAF sensor. Current location for the MAF is directly across from the oil cap. Any ideas on what or how to run the other side?
Thanks,
Mike
Thanks,
Mike
Air filters are separated from the wrapped headers by insulated panels and will be fed cool air from a roof scoop and side scoops. Below the panels will be ventalated with cooling fans.
Use one of the late model mafs and put it in the pipe anywhere you want...custom tune though. I am thinking of doing what you are. Do you have any idea what your final weight will be?
Thanks for all the replies, even the one from the ********.
