lets talk about LS7 HEADS ....
Old 08-23-2009, 09:23 AM
4evervette's Avatar
Default lets talk about LS7 HEADS ....
i have been searching here and there ..looking for options
so far :
West Coast Cylinder Heads ..
Precision Race Componets CNC Ported LS7 Heads:
ETP heads ....
any one hae used any of the above or any other option plz chime in with ur experience ....
what typicall cost ??
do u need to change rocker arms or not type of valves ?!
what are the avreage HP gains ..?
thanks
Old 08-23-2009, 10:25 AM
davidws6's Avatar
Default WCCH LS7's
I got a set from Richard @ westcoast + a mamo ported LS7 intake. I really don't remember the total cost but it was around $3300, I think. Call him, he knows his stuff ! I would'nt mind trying the fast 102mm but no good comparisons yet. + lots a dough for that intake !
Richard re CNC's the exhaust yet leaves the intake alone. I polished up the intakes the best I could to get rid of the rouch CNC ing that GM did.
The PRC's are nice too, but I don't think they do anything to the Exh ports?
I've had 0 problems with the heads. Had to drop the engine for a bad lifter n went with the Morels.
I used Harland Sharp LS7 Roller Rockers that bolt right to the factory pedistal. I think they cost + - $650 7.475 pushrods.
I'll Finally get some dyno numbers when I fly home 4 labor day.
Old 08-24-2009, 06:51 AM
Dutchman427's Avatar
Talk to Richard @ WCCH. As stated...he knows his stuff. I have a set of ported LS7s on my build by him. I am very happy with them.
Old 08-24-2009, 09:11 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Actually, alot of the power gained by the PRC port work on the LS7's comes from the work on the exhaust side of the head. PRC does both intake and exhaust.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-24-2009, 04:48 PM
Gordon0652's Avatar
Thats why i bought mine from you!
They will be at my door tomorrow!!! Thank You!
Old 08-24-2009, 05:01 PM
SmokedOutZ28's Avatar
Do You need to change the valve covers to run LS7 heads or can you run LS1 valve covers?
Old 08-25-2009, 05:50 PM
DBN
DBN's Avatar
I have had great results with my ETP LS7 heads. I am running stock LS7 rocker arms.
Old 08-25-2009, 06:01 PM
davidws6's Avatar
Default Valve Covers
Had to use the Scoggin Dicky 3/4" spacers for the clearance of the Harland Sharp LS7 Rockers. Other then that, all good !! So far no leaks r noise, which is a good thing !!
Old 08-26-2009, 07:26 AM
4evervette's Avatar
can u shear with us ur results ..and from where did u get ur heads and how $$$ did it cost u ?
Old 08-26-2009, 07:29 AM
4evervette's Avatar
thank for the great info ..so far it seem every one are happay with WC head and PRC...
Old 08-26-2009, 07:31 AM
4evervette's Avatar
how much out rights PRC ls7 head will cost ..???
Old 08-26-2009, 09:15 AM
http://www.texas-speed.com/shop/item...d=912&catid=40
There's the page with the options and such
__________________
Old 08-26-2009, 09:48 AM
DBN
DBN's Avatar
This should give you an idea of the performance results http://www.youtube.com/watch?v=p4rBVdM7yjY This is a 427 N/A engine with GM LS7 intake/TB and hydraulic cam running through an A4 transmission. The heads were part of a complete engine that I bought and had rebuilt. I can put you in touch with my engine builder if you are looking to build an engine.
Old 08-26-2009, 10:39 AM
Cliff's Avatar
ETP makes good 427 heads but they are expensive and you have to use Jesel rockers for correct alinement's. The Jesel rockers are expensive.
Old 08-26-2009, 10:41 AM
DBN
DBN's Avatar
Jesel rockers are only required when running a solid roller camshaft. I am running stock LS7 rockers with my ETP LS7 heads.
Old 08-26-2009, 02:19 PM
kumar75150's Avatar
I bought my LS7 heads from LG motorsports. I cant tell you much but my car (07 Z06 with all headers, CAI, ported tb and intake) made from 590-605rwhp with a ~245 duration cam.
Old 08-26-2009, 05:57 PM
davidws6's Avatar
Default Exh flow vs PRC n WCCH
According to the info on the PRC heads,
@ 600 lift the PRC flows 235CFM 700 is 246 CFM
@ 600 lift the WCCH flows 244 CFM 700 is 250 CFM
Info from Richard @ WCCH
I don't remember what the Intakes flowed as I can't find my spec sheet.
Old 08-26-2009, 06:09 PM
Jason 98 TA's Avatar
We've gone well into the 600rwhp range with stock bottom end LS7s & 750+flywheel hp with the LS7 on a street 454 LSx Shortly you'll be able to buy the PRC LS7 head in a thicker ETP casting incase you guys need 6 bolts or thicker decks!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-19-2009, 10:18 PM
lfsglass's Avatar
I saw a Z on the dyno today with ETP's and......well......all I can say is it was less than impressive (more of a disappointment than anything).
Old 09-19-2009, 10:42 PM
Stage7's Avatar
Can you elaborate? Setup, cam, etc?
Quick Reply: lets talk about LS7 HEADS ....
