lsx blocks , eating camshafts and lifters?
greetings everyone
we have a 427 and a 454 ( procharger at 13 psi) that are eating camshaft and lifters.
we have tried diferent springs, lifter brands and lastly a solid cam and lifter combo. NONE worked. The funny hthing is the NA 454 is OK after many passes.
Do you have an idea what could be happening?
thanks
thanks
LS1Tech Premium Sponsor
Are you running the lifter trays that are supplied with the block or a tie-bar lifter? We found a few sets of those trays that were not perfectly straight and had the lifters rolling on the cam kind of sideways. After that, we only run tie-bar lifters in any LSx block build we do!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
After assembling an LSX and finding the cam being too tight, the cam journal was pretty bad, needed to take a few thou out.
Now on we hone the cam journal, and had custom size coated cam bearings made.
what we've done to new LSX blocks is hone the cam journal .002", we find they're on the tighter side of the tolerance.
In GMPP book theirs numbers for oversize LSX bearings, .005" larger
I have not seen the problems with lifters in these engines, but I rarely use the lifter guides supplied with the block. Certain cam/lifter combonations will bottom out in the retainers before full lift also, causing issues.
Kurtr
Kurtr
Yep we only use the link bars in LSX deals as like Kurt said a Crane or Morel drop-in style lifter will break the lifter guides that come with these deals if you aren't careful and use spacers so we just don't use them anymore but only the link bars.
Also have to turn some cams down a bit and hone the cam tunnels every once in a while. I feel sorry for a regular guy trying to assemble one of these deals on their own because it's a disaster waiting to happen if you aren't careful.
Geez, I am putting my build list together and now I have to be concerned with more issues.... what gives? At least I found out here rather then trying to searcht he problem after the fact of more money wasted.
Who would you recommend to have an LSX block prepped near the North Carolina area? I am in the process of building a 427 LSX/AFR setup for boost in a drag car and am curious what the concensus is about builders and who has good experience with these bowtie blocks!
Thanks in advance!
Chris
Thanks in advance!
Chris
Boy am i glad to hear about these issues before I drop the coin on a LSx block.
Hmm might have to reconsider.
Why can't those monkeys at GM build anything normal for the Hot Rodder? There is always a catch, always.
I did some research and it seems to be quite a common issue
F*** this, LS7 blocks have issues, C5R are atrociously $$ and can have issues.. Grrrr..
LS3 blocks?
LS3 blocks?
If your a qualified engine builder then you can deal with it and it's not a huge deal. It's just not a good idea for the inexperienced person to try and build an engine and this is one of the reasons why. What are you going to do when something isn't perfect? (doesn't just pertain to the LSX block). This is all part of engine building 101.
lcvette We are not in the NC area but we can assist you if you do not find someone your comfortable with.
Thanks in advance!
Chris
Thanks in advance!
Chris
Give us a call
I call that inferior quality, especialy for a product comming out from a giant of the industry with highly paid workers and countless hours of testing.
Now a lot of these LSx blocks issues were determined after being put together and failing.
Your logic would dismiss the majority of hot rodders as consumers if only mechanical engineers would be the only ones left to build motors.
Basicaly my point is those issues should not exist once the product hits the market.
Granted blueprinting, slight deburring etc... is part of the whole process but to have to remachine certain parts is not part of that criteria in my book.
