AFR L92 Style Heads
Old 01-17-2010, 01:31 PM
MGGLS1's Avatar
Default AFR L92 Style Heads
Anyone have any dirt on these...heard something about them on another site, but no details.
Matt
Old 01-17-2010, 07:08 PM
Steve1969LS1's Avatar
Last time I talked with Mamo he hinted at mid January.. I guess I should call him
Old 01-17-2010, 07:17 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I didn't think they had plans for the L92/LS3 style heads...maybe I'm wrong
Old 01-17-2010, 07:45 PM
ss1
ss1's Avatar
They were talking Jan-Feb for the 215cc heads cathedral port heads. I haven't seen anything about an L92/LS3 style head either.
Old 01-17-2010, 09:47 PM
I talked to Tony Mamo last month.. I'm pretty sure he mentioned them. I will call him tomorrow to confirm
Old 01-18-2010, 07:15 AM
MGGLS1's Avatar
Thanks Steve, considering how well they did the LS1 heads, it should be interesting to see their version of the L92's.
Matt
Old 01-18-2010, 03:29 PM
ringram's Avatar
Spoke to him recently. No immediate plans for L92 type heads at present IIRC.
Old 01-19-2010, 02:25 PM
mike c.'s Avatar
I also heard this too. Just not from AFR. Just wait and we'll see.
Old 01-19-2010, 07:55 PM
supermouse4's Avatar
If AFR can improve what GM has done with L92s and can keep them at a similar price, that would be awesome.
Old 01-20-2010, 11:35 AM
Bring the Noise's Avatar
Default Off subject....
I'm waiting to see what happens with the Direct Injection (DI) heads that GM prototyped back in late 2007 early 2008.
It was suppose to be the same chamber and runner layout as the L92, but with the injector nozzle sticking out into the combustion chamber (not mounted in the manifold).
The DI 4 cyl (Solstice GXP/Sky Redline SC 2.0L) and the Gen 5's DI V6 show good results. But neither chamber is designed for Swirl on the intake stroke (Quad valve setup).
The V8 heads (mainly the L92 and LS7 heads) with the offset intake promote Swirl on the air fuel to increase the mixture (which increases the percentage of fuel combusted).
I think the DI version of the L92/LS3 heads (if they are ever released) will be hard as hell to beat.
Another question to do with the DI setup.
What do you do with the injector locations on the standard L92/L76/LS3 manifold as the fuel rails and injectors should mount under the manifold for a DI setup?
Old 01-20-2010, 01:12 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
It would not be cost effective to try DI on a non DI setup. Piston design is different for the most part, as well as them needing an injection pump (just like off a diesel) to make the fuel pressure go high enough. There would be no room anywhere on the manifold because the intake port takes up all that space. My conception of the idea would be just like a diesel is now with it straight in the top, or on the side of the head by the spark plug. Those are really the only feasible places. If they are in the top, then that means a different valve cover.
You would not use the same manifold either. Just like the change from carb to tbi to MPFI changed manifold design, so does the change from MPFI to DI.
Cost would add up very quickly on a car that was not normally set up for this.
And as far as chambers being designed or not designed for "swirl" I wont comment on that.
Old 01-24-2010, 06:50 AM
flatchat's Avatar
Any news from AFR on if , when or not they are doing the heads?
Old 01-24-2010, 02:50 PM
mike c.'s Avatar
The old motors are done. The new ls motors have a different design head. It seems the aftermarket world would produce a ls3/ls7 head for the new and future motors. I have heard heads are coming,just like some of you. Just sit back and see what happens.
Old 01-24-2010, 08:14 PM
66deuce's Avatar
check out Mast Motorsports for an aftermarket L92/LS3 head..
Old 01-25-2010, 06:07 PM
mike c.'s Avatar
i heard of mast. like i said,sit back and wait.
