Cam for a 416???
Old 01-23-2010, 12:43 PM
RENE'S RAGE's Avatar
Default Cam for a 416???
Need a cam for my 416. LS3 block, Lunati 4.0 crank, 6.125 rods, Wiseco flat top -3cc pistons, 11:3 to 1 compression, Fast 92/92 and last but not least
TEA TFS 235's
Track car only. TH -400 w/brake and around 5000 stall, 4:11 gears.
I need a bad *** cam for this set-up, not the biggest cam, but one that will work great with this set-up.
Old 01-23-2010, 01:05 PM
XtraCajunSS's Avatar
I have a custom grind in mind that would work great with that setup. Low 250's intake, high 250's exhaust. mid .600" lift. PM me if interested. We've used it with great success in builds such as yours. I'll give you the exact specs via PM.
Thanks,
Shane
Old 01-23-2010, 01:32 PM
Thanks,
Shane
Thank you Sir, PM sent!
Old 01-23-2010, 01:46 PM
PM replied to
Thanks,
Shane
Old 01-23-2010, 04:47 PM
99T/ATIME's Avatar
Sounds like a nice set-up you have there. Good Luck.
Old 01-23-2010, 07:46 PM
Thank you Sir!
Old 01-25-2010, 03:48 PM
Anyone else.
Old 01-26-2010, 01:39 AM
99blancoSS's Avatar
I like Thunder Racing cams (was my first cam and I'm still partial to them ) Shane will hook you up.
Old 01-26-2010, 05:32 AM
I like what Shane has said in our PM's.
Just looking for other opionions.
Old 01-26-2010, 06:05 AM
baezi z06's Avatar
I´m using TSP Cam TXGiant 248.254-615.622-114 in 402
i like it a lot........ fat tQ, mean manners...
could be good/fun in 416ci
good luck picking a cam
Baezi
Old 01-26-2010, 07:57 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
We have a cam that I think you would like. It is a 253/264 HR110 0.601I, 0.585E. With a 6.2L and LS3 heads it makes peak tq around 4900 and peak horsepower around 6500. The HP on top was withiin 15 hp of peak for 1400RPM on top!!!! Oh, it does have a mean idle.
Old 01-27-2010, 01:43 AM
kumar75150's Avatar
Similar to what a couple other guys have suggested, I had a cam speced by Futral that was 253/261 around .650 lift in my 408 that made great power. Several guys had the exact cam with good numbers back in the day.
Old 01-27-2010, 06:34 AM
NXZ28's Avatar
I have a Schwanke 415 LY6 motor with AFR 225 Heads and a TREX. It went 6.89@100 in the 1/8th on 7 cylinders. Found out the TREX ate one of my LS7 lifters. I just bought the Texas Speed Giant Cam and I should be testing it at Pinks in Florida at the beginning of March.
Old 01-29-2010, 07:29 PM
hymey's Avatar
250s cam works well, Its good to hear people are speccing bigger stuff for LS3, broken LS7 lifter? Never had issues with mine with 240s cam, had the motor down and there perfect, much better then the LS2 lifters and quiet, Most lifter issues stem back from the valve/spring combination and float and/or preload, which exerts the stress back to the lifter.
Old 01-30-2010, 09:14 PM
thedak's Avatar
A 6.2L and LS3 heads.
That is big...
I am installing a 235/243 .621 113LSA LSr in my 416.
Old 02-01-2010, 09:40 AM
LS1TECH Sponsor
Originally Posted by thedak
That is big...
He's not driving it on the street!!!
Old 02-01-2010, 10:37 AM
LS1Tech Sponsor
Slowhawk's Avatar
I like the Schwank recommendation.Only problem I see is the FAST choking above 6200rpm.With a 5k stall I would expect shift points at 7000-7400rpm.
Old 02-01-2010, 11:44 AM
94 guy's Avatar
only problem i see with big cam ls3 motors is i don't see any good times or mph show me times with weights of the car.
Old 02-01-2010, 07:42 PM
Yeah, now I'm going with a Vic Jr and 4150 TB.
So now I need another cam choice.
It never ends.
Old 02-02-2010, 05:09 AM
LS1Tech Sponsor
Slowhawk's Avatar
It never ends.
Then I still stand by my answer since I brought out it should have that intake combo
In my car I run a smaller cam with more cubes and a super victor intake.
Quick Reply: Cam for a 416???
