LQ4/LQ9 gasket list
LQ4/LQ9 gasket list
I got this list from GM Parts Direct. I asked for the gaskets for a LQ9, but this is what I got so I am assuming that they are the same. I was also told by Jon at TSP that the LS1 and LQ9 gaskets are the same except for the head gaskets so I am guessing that these will cross reference with the LS1 part #s.
I am having my LQ9 freshend up from top to bottom and I really didnt want to reuse any old seals or gaskets. Does this list look complete? Is there anything missing or stuff I won't need? Thanks!
89060436 crankshaft rear oil seal kit reverses lip LQ4.
12633578 crankshaft rear oil housing seal LQ4.
12612350 engine oil pan gasket LQ4.
12611384 engine oil pan cover gasket LQ4. Requires to be used with part number 11588714 bolt, two required.
3536966 engine oil drain plug seal, offered as a package quantity of 10 LQ4.
10151633 engine oil level sensor seal offered as a package quantity of 5 LQ4.
24504031 engine oil level indicator tube seal LQ4.
12570307 water inlet seal LQ4.
12630223 water pump gasket requires to order 2 LQ4.
12585673 engine front cover seal LQ4.
12633904 engine front cover gasket LQ4.
12551933 engine coolant air bleed pipe seal, two required LQ4.
12602540 engine coolant air bleed pipe cover, two required LQ4.
24100002 engine oil filler tube seal offered as a package quantity of 5 LQ4.
24100002 engine oil filler cap seal offered as a package quantity of 5 LQ4.
89017253 cylinder head gasket kit, without cylinder head bolts, includes gaskets for heads, intake, exhaust manifold valve covers, and engine coolant air bleed pipe o-rings/seals, LQ4.
12558178 engine block valley cover gasket LQ4.
11588291 first design with adhesive patch cylinder head bolt, 16 required M11X2.0X155 requires to order as needed LQ4.
12560745 first design with adhesive patch cylinder head bolt M11X2.0X100 offered as a package quantity of 5 LQ4.
OR
11571134 design M11 X 100MM, 20 required requires to order as needed LQ4.
12558840 cylinder head short bolt M8X1.25X45 offered as a package quantity of 10 LQ4.
OR
Geez... I just looked up the intake manifold gaskets and the LS3 (19172114) gaskets are $40 each but the LS7 (19172113) gaskets are $13 each... why?
edit: OK I think I messed up on this. I just noticed that these p/n are for "carb" intakes. I have a regular LS3 intake, not a carb style. Does anyone have the p/n for the gaskets, I am only finding the carb style.
edit 2: Ok the p/n I found for the LS3 intake is #89017839. They are sold as 2 per pack (1 pack per port) so I am guessing I need 8 packs right. But then I found these p/n #12533587 and they are sold as a kit. What is in the kit to justify the added cost over buying them each?
#89017839 = $4.60 x 8 / $36.80
#12533587 = $85.39 Set
WOW! GM Parts Direct has really great prices but their shipping kills any savings. I just got off the phone with summit racing and they will not only beat the price of each gasket by $1 but they will also ship for $12. That is a savings of $100-/+
I also found ARP studs (234 4317) for $215 so I'll add that to the summit purchase and save a $1 plus $20 shipping
My concern is the list of gaskets I posted in post 1. Is there anything I am missing or is there anything in the list that I dont need? What I am doing is building a LQ9 for my t/a it is going to get tanked and honed. I really did not want to reuse anything, but I was told that some things can be reused without issue. Should I just bite the bullet and get everything listed or is there somethings in the list I dont need. As for the bolts (head, mains, rods, cam) I was going to use ARP. thank you for your help.
OR
OR
A good supporting vendor here can get you everything you need. That's the good thing about a supporting vendor, they can give you the info. you need and not just a price on a website. IMO, it makes it worth paying an extra buck or two to be able to call and speak directly to someone who knows what they are talking about rather than just looking at part numbers on the web. Let us know what you are looking for and I'm sure we can get you fixed up.
Jon
Jon
How did it go for you? I did all that stuff too but I think I messed up on the head gaskets. I'm using a 6.0 block and 853 heads from a 5.7 LS1, bought head gaskets for the 6.0 and it's leaking in the middle of the driver's side head. Should I have bought 5.7 LS1 head gaskets?
BTW, your list looks good. Small fortune on those dam sensors as I found out.
