Building a iron 370.... buy a new block or search for used block.. Pros/Cons?
Im getting ready to start a motor build and Ive decided on a forged iron block 370.
My first instinct is to get a brand new block as they are cheap as hell new. However I have heard that a "seasoned" (insert USED) iron block is a better choice due to it being heat cycled already and less prone to distortion over time or during break in because its been used.
It seems a relatively low mile used LQX short block can be had for the same as a new LQX bare block new.... my thoughts are its a win win because a used short block comes with all the nick-knack bolts/covers that can be reused on a build. If there is truth to using a "seasoned" block then this makes the decision a no brainer.
Anyone care to share thoughts on this?
Thanks in advance...
avengeance, i am doing the used block. just to have sensors,pan, covers,rockerarms,etc.... hopeing for a painless 5.3to 6.0 swap
i have also heard pros about using a rebuildable seasoned block, also curious as to what others will say.
thanks for posting
thanks for posting
Anyone care to share thoughts on this? Thanks in advance...
here is the link....
https://ls1tech.com/forums/parts-cla...ain-studs.html
Used can be slightly better as long as block isn't really used and cracked and overheated etc. All brand new blocks will move a tiny bit as they age and take a set and stabilize. NASCAR and PS stuff is new but also is stress relieved and gets freshened now and then by the time they run down the track.
A new block is a great option and will have to do some research before any future builds.
Smokey Yunick used to bury blocks in the ground to season 'em, he claimed the corrosion actually hardened the blocks.
I believe I'll pass.
For most of us, there's not enough difference in dimensional stability between a new and seasoned block to worry about.
Regardless I wouldnt lose sleep either which way over it. I'd be MUCH more concerned about who puts it together and does your machine work than I would be about block integrity. Human error is a LOT more prevalent in engine failures than seasoned vs unseasoned iron stability
