Valley Cover seals part # ?
Has felpro come out with their gasket and O-ring kit and what is the part #
What are the GM part no's if anyone has them?
Thanks
Thanks
You didn't say for an LS3. Please be specific when asking for part numbers. This is the whole kit which includes: valley cover, gasket, (8) O-rings, PCV baffle with screw.
GM part # 12599296 COVER,ENG BLK VALLEY & (W/PCV BFL)(INCLS 506,537,556,908,909) $121.28
Thanks!
Found this
FEL-PRO Part # MS96871
Lifter valley cover set; For use when servicing Displacement-On-Demand solenoids
Has anyone used this? Is this the perimeter gasket + O rings in one box? Rock Auto sells this for $60
The $32 one from gmpd that thunder racing has is for a non dod cover.
If the engine is not together drill and tap the towers for 1/8" pipe plugs and don't use the o-rings. Gaskets can leak plugs will not.
The Felpro valve cover gaskets are JUNK. Get the black GM ones they don't expand with heat.
Tim
