Mill Heads or Thinner Gasket?
Old 06-24-2011, 10:50 PM
89ROC-Z's Avatar
Default Mill Heads or Thinner Gasket?
What's better? Milling my 823 heads .020" for ~65cc chamber, or running thinner head gaskets?
What thinner head gaskets are people using?
Thanks guys!
Old 06-25-2011, 10:48 AM
3pedals's Avatar
both
Old 06-25-2011, 11:00 AM
litle88's Avatar
Is this going into your 6.0?
If so where do you wanna be in compression?
By milling to 65cc's and a stock .051 gm mls gasket I think you'll be at 11.2ish.
Old 06-25-2011, 02:16 PM
89ROC-Z's Avatar
Originally Posted by 3pedals
both
DOn't want to run into PTV clearance issues...although my new motor will have JE's with reliefs in it.
Yep going into a 4.005" bore 6.0 with flat tops. I'd like to be ~11.5 and i'll be running nitrous
Old 06-25-2011, 02:24 PM
NemeSS's Avatar
both.,
or run as tight as quench as possible.with gaskets and out the bore measurement. i aim for .035-.040 quench on any build.
example:
piston out the bore .015
gm .051 compressed gasket
= .041 quench
Quick Reply: Mill Heads or Thinner Gasket?
