Good option? L76 w/ 243/247 .621/.612 114+3?
Old 01-25-2012, 04:37 PM
LSxChevelle's Avatar
Default Good option? L76 w/ 243/247 .621/.612 114+3?
Looking at buying a used cam from a member.
Picking up a L76 sat and will be removing VVT and AFM. (May add VVT back later) So L92 heads which I may have the exhaust ports ported a bit since I hear thats where they could use some help.
Cam is 243/247, .621/.612, 114+3 LSA
Good option?
Old 01-25-2012, 05:41 PM
godlyxdan's Avatar
what other mods, and what are your goals?
Old 01-25-2012, 08:24 PM
LS3 intake, cnc TB, and headers. And yes valve springs....
Old 01-25-2012, 08:44 PM
I've just been reading info about duration for l92 heads on stock stroke 6L/6.2L motors.
Also I will run a TH400 behind it for now.
Old 01-25-2012, 10:05 PM
1badeagle's Avatar
From my endless reading I'd say more split with less duration on the intake side.
Old 01-25-2012, 10:13 PM
Tainted's Avatar
That cam is way to big, you will have to flycut almost indefinetley. ls3 heads like a lot less intake duration, a wide split, and tight lsa
Old 01-26-2012, 12:54 AM
Being auto (th400) should I go for something like a 230/230?
Old 01-26-2012, 02:21 AM
Mr. Sir's Avatar
Perhaps a 224/230 114+3 for good overall power. 228/235 113+3 for more focus mid to top end.
Old 01-26-2012, 03:51 AM
Dyno Junkie's Avatar
I run a Comp Cam in the LS3 in our Monaro.
Specs are 231 239 .617 .624 113.
Old 01-26-2012, 10:17 AM
Tainted's Avatar
Instead of using an off the shelf ground cam, why not have someone like Pat G spec you a cam based on your build and goals? Best $25 ever spent
Old 01-26-2012, 10:47 AM
I will for my final setup...
For now I will keep my eyes pealed for a used one. The one I originally mentioned is$230 shipped. Seems about the range I've spent in the past.
Old 01-28-2012, 10:10 AM
LS1 BU's Avatar
To big. I run a smaller cam in my 418 l92. I used to run a cam a little bigger than that and the driveability sucked. Went to a smaller grind and picked up power and driveability.
Old 01-28-2012, 07:21 PM
litle88's Avatar
Save yourself the trouble bud and just call Comp tell them what heads, intake, rear end and gear, weight and your goals and they'll hook you up. Just my .2
Old 01-29-2012, 01:40 PM
L92 fox's Avatar
Don't cheap out on the cam. And rectangle ports are very picky with cam selection. 25 dollars to pat g and 400 shipped for the cam from eps is worth the money.
Old 01-29-2012, 02:05 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
We have several camshafts that have been proven in similar applications. Although, if you are still interested in going with a custom grind, we can spec you one out for $389.99.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 01-29-2012, 03:19 PM
LS1 BU's Avatar
comp is a joke. They have no idea about cam specs for these heads. Comp likes to overcam the l92/ls3 combo's. Saw an article awhile back where comp spec'd some 25x/26x cam on a 408 with ls3 heads. Made like 580 or so flywheel hp if i recall. I made more with way less overlap. Need to keep the air speed up with the huge rectangular ports.
Quick Reply: Good option? L76 w/ 243/247 .621/.612 114+3?
