Post details of your L92/LS3 headed combos here...
Old 03-10-2012, 08:48 AM
65SSZO6's Avatar
Default Post details of your L92/LS3 headed combos here...
Hey LS1Tech guys and gals,please post up your L92/LS3 headed combos here.I am building a LS3 intake and headed LQ4 and want some ideas of cam specs,how much milling,HP and Torque your combo made.Thanks for helping me get rid of some of these question marks.
I'll go first
Piston:.020 over Hypereutetic 9cc dished
L92/LS3 milled:.010-.030?
Cam Specs: 22?/23? .59?-.61? lift on 11? LSA +2-4
HP/Torque: Hoping for 440-460HP and Ftlbs thru a 200R4 and 3.37 12 bolt
Dyno sheet: This is my old combo with 317 heads,LS1 intake and 04 ZO6 cam
Attached Thumbnails Post details of your L92/LS3 headed combos here...-dynograph.jpg
Old 03-10-2012, 10:04 AM
Dyno Junkie's Avatar
LS3 crate engine with 231 239 .617 .624 113 Comp Cam, good enough for 11.38 @ 120mph in a 3880lb Monaro.
Old 03-10-2012, 10:13 AM
Imstock2's Avatar
ls2 c6
milled .015
thinner 3 layer metal head gasket .04
228/232 .588/.595 lift 114 LSA
I didn't PP the heads but I did clean up the casting
Will have dyno results from rpm friday
Old 03-10-2012, 12:39 PM
01 blue ss's Avatar
416 LS3 block. 4.070 bore 4.0 stroke.
Callies crank and rods, Wiseco pistons.
L92 PRC ported heads upgraded .650 lift springs.
LS6 ported oil pump, N-motion double roller chain,
EPS custom ground 240/251 636/621 114 LSA cam
FAST 102 intake
Cometic .040 gaskets
Lunati tie bar 72532 lifters
TSP pushrods
Old 03-11-2012, 05:06 PM
MASS seller approved
low2001gmc's Avatar
Originally Posted by Imstock2
ls2 c6
milled .015
only 4 degree split in cam. interested in how it will respond and dyno numbers.
72 nova project. lq9 with ls3 heads slightly ported on exhaust, self ported l92 intake (l92 dyno proven to outflow ls3), all bolt ons, undecided on cam but considering eps 226-234 due to ls3 heads. if 243s, would have gone with fti streetsweeper ht 228-232 cam. thats why im interested in your combo personally good luck, rob.
Old 03-11-2012, 05:21 PM
Imstock2's Avatar
You can follow my thread if you want I like driveablity and the cam is spinmonster speced... He made 470ish with simular bolt on's on his with my heads and intake.. now he has a light flywheel and I have the z06 clutch,flywheel but I got my heads milled and cleaned the casting up. He has haltech cai and 103 MAF but I have K&n system stock MAF
https://ls1tech.com/forums/generatio...uild-list.html
Old 03-12-2012, 12:25 AM
bww3588's Avatar
370 iron block
Stock cleaned up ls3 heads and intake
Wiseco forged flat tops with 3.2 cc valve reliefs.
11.3 static compression.
1 7/8 stepped headers
9 inch out back.
Still haven't ordered my custom cam but it's coming soon.
Old 03-12-2012, 12:56 PM
65SSZO6's Avatar
Thanks for the info guys. Keep the builds coming!
01 blue SS what kind of HP &Torque you put down?
By my count 5 out of 7 of us are still works in progress,or waiting for tunes etc. WHERE ARE THE RUNNING BUILDS WITH #S?
Old 03-12-2012, 02:34 PM
Tainted's Avatar
I got a stock as a rock L76 does that count?
Old 03-12-2012, 02:41 PM
hicksport's Avatar
2008 ly6, l99 intake, truck tb, lt headers, TSP vvt-2 cam, t56. 431hp 412tq
Old 03-12-2012, 10:21 PM
cam75w/ls1's Avatar
Here's mine from awhile back. Been running it down the track recently and still dialing in.
https://ls1tech.com/forums/generatio...-critique.html
Old 03-13-2012, 06:01 AM
cabel1's Avatar
Still in progress. L92 bottom end, ported L92 heads, Pat G cam, PRC springs, LS3 intake, Fast 90tb.
Old 03-13-2012, 03:51 PM
01 blue ss's Avatar
Make me number 6 then. I'm not done yet. I hope for over 520 rwhp thru a th350 and a 12 bolt
Old 03-13-2012, 04:44 PM
litle88's Avatar
I'm almost done! I have pics on the litle88 thread in the Midwest section
Set up is an Ls3
4.0705 bore
4.0 scat crank
Eagle H beam rods
Manley pistons w/-2 valve reliefs and hellfire rings
Morel street linked lifters
Short Block built by AES all piston skirts rod and main bearings were coated as well.
Comp pushrods
Comp 243/259 .624I .624E 114+3 on LsR lobes
LPE Ls3 heads with comp 925 springs, mollee to 65cc's
Fast 102 Nw102 TB
INTAKE was matched to the runners with the help of Chris1313
Kooks 2" headers kooks ypipe
I should be done by next weekend and then off to Straightline for tuning hoping for 1st week in April!
Old 03-13-2012, 07:09 PM
99vertA4's Avatar
05 a4 vert c6
L92/l76
231/240
Milled .030 stock gaskets
3.42 gears
10.78@124.33. 1.43 60'
Old 03-14-2012, 01:00 PM
87silverbullet's Avatar
Originally Posted by 99vertA4
05 a4 vert c6
L92/l76
231/240
3.42 gears
I'm assuming thats on motor?
Old 03-14-2012, 06:04 PM
topbrent's Avatar
05 a4 vert c6
L92/l76
231/240
3.42 gears
What converter are you running?
Old 03-14-2012, 06:15 PM
OrangeGoat's Avatar
2006 A4 GTO
L96/L76
Baby Cam
Soon to be milled .030
Stall
CAI
Full Exhaust
Before heads 11.8X
On Nitrous (125) 11.4X
NEW Times Coming Soon after install completion.
Old 03-14-2012, 06:30 PM
OrangeGoat's Avatar
99verta4...what push rod length you using?
Old 03-14-2012, 09:52 PM
99vertA4's Avatar
Yes all motor full drive weight except my 275 Hoosiers are on c5 z06 front wheels which are lighter than my regular wheels n tires. With stock converter and stock 3.15 gears my best time was 11.69@121.56. That was after ALOT of runs to get there bcuz that big of a can doesn't play well with a stock converter. Very first run with my yank ss4000 and 3.42 gears was 10.94@122.5. After more tuning and experimenting with launch my best time is 10.78. I think the DA was 1200 that day. I expect to run a 10.6? With a little more tuning when the track opens here in indy
Quick Reply: Post details of your L92/LS3 headed combos here...
