what is the highest compression you have run on pump gas
Old 04-01-2012, 02:02 AM
newbrian's Avatar
Default what is the highest compression you have run on pump gas
I have an 1st gen small block that is 12.1:1 compression that I run on pump gas. I Run conservative timing and have run 11.89 @ 118 in the quarter with it. It has 49 cc chambers with steal shim head gasket and flat top pistons. I know it will do better times in the quarter but i have traction problems off of the line. My 60 ft time was in the high 1.70s. This leads me to my current build a lq4 402 stroker. I was planning on trying for 11.7:1. Does this seem impossible on pump gas with fuel injection. I will use a cam that will get my dynamic compression below that of the sbc in the camaro. I want keep the compression up to mitigate the low rpm torque losses due to the cam. I am currently on the fence on the compression. I may play it safe and go with flat tops and 11.1:1. What do you guys think?
Old 04-01-2012, 12:17 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
I had a 422 cid iron block stroker in 2000 and it was 12.2:1. But I ran conservative timing and the cam profile will help/hurt as well.
Old 04-01-2012, 10:45 PM
newbrian's Avatar
I am planning on running the comp cams xr275hr-12. From what I have read so far it looks like torque will be higher every where on the curve vs stock cam. As long as torque is higher I should be able to maintain gas mileage. It may even pick up some since the torque is higher, in theory it would mean the engine is more efficient. I guess I will find out. I should also be ok with stock converter as the recommended range on the cam is 2000 rpm on the bottom end. I have found the truck doesn't run under 2000 very often with 4:11 gears. I am not to concerned about around town mileage anyway. What I can't afford is 10 mpg on a long trip. I am usually over 2000 at highway speed. If I do have to change the converter it shouldn't affect mpg on highway due to lockup.
Old 04-02-2012, 09:21 PM
The1N_only's Avatar
For whats its worth im sitting at 12 to 1 and I run 26 degrees of timing around peak hp and 20 at peak tq. 12.5 to 1 seems to be the limit on 93 octane and be able to run a decent about of timing. Your cam does play a decent roll as it affects your dynamic compression.
Where the converter will come into play is keeping you from pushing through the brakes when you are stopped.
Old 04-03-2012, 09:33 PM
newbrian's Avatar
Thanks for the info. I decided to go .030 over so I had to go flat top. The domes would have put me near 12.4. I would be willing to risk it on a toy, but can't afford it on a daily driver.
Old 04-05-2012, 02:06 AM
03EBZ06's Avatar
I have 11.7:1 RaceTech pistons in my 416. I have run the 247/255-113 cam and a 204/218-117 cam in this motor. With the larger cam, 22 BTDC. With the smaller cam, 21 BTDC. It wasn't "that" much of a diff in spark control, except midrange needed about a 2 deg reduction. The real trick is the right plug heat range. My engine uses 91 octane Kalif gas and on race day a splash of 110.
Old 04-05-2012, 11:51 AM
sman's Avatar
6.0 running 12.1 here, timing around 26 IIRC. Run anywhere from 91 to 94, I buy the highest available at whatever gas station I stop at happens to be. Was given specific instructions from the tune NOT to get anything less than 91 though.
Old 11-29-2013, 11:42 AM
1972chevyls1's Avatar
How is you fuel mileage with the higher compression?
Old 11-29-2013, 12:04 PM
newschool72's Avatar
Higher compression "generally" gives better fuel economy because the engine is more efficient . Notice I said generally, because there are many things that contribute to good fuel mileage .
Old 11-29-2013, 06:28 PM
I'm trying to get max HP and keep it street able with some what good milage.
Old 11-29-2013, 06:30 PM
427zm's Avatar
I'm in the process of an ERL 434 LS7 build that'll be 11.8-12.1 static and I plan on running pump. Sure hope I'm safe when's she's together! I don't want to be forced to run E85.
Old 11-29-2013, 08:31 PM
N20zuki's Avatar
Comparing a LS to a Gen I is kinda not going to be the same, chamber design and head material have a lot to do with detonation in a GENI as well as cam profile. With a GENI you need to watch what your dynamic compression is almost more important then static compression. Honestly I have never heard anyone ever talk about dynamic compression when it comes to cam selection on this site with a LS series lol.
I have seen people with 12.5-13.1 with a LS motor on pump gas... I would shoot 12.1-12.5 to be safe.
Quick Reply: what is the highest compression you have run on pump gas
