whats the best LS3 cam ?
Old 08-07-2012, 02:08 PM
PROMODLSX's Avatar
Default whats the best LS3 cam ?
Getting ready to buy a bigger cam for my new LS3 crate engine going in a 78 camaro with 4L65E with a 3600 stall. looking for rough idle and all around tq/hp gains thru out the rpms. car has 3:73 gears. prob lean a little more to the bigger side. any Ideas?
Old 08-07-2012, 03:02 PM
Jimbo1367's Avatar
Do a SEARCH for Patrick G. Have someone proven spec you a cam. Just pay the $25.oo It will be the best $25.oo you spend.
Old 08-07-2012, 03:06 PM
Tainted's Avatar
bigger is not always better. smaller cams are gonna give you way more useable power and better street manners.
and there is no "best" cam
+1 for pat G
Old 08-07-2012, 03:10 PM
Jimbo1367's Avatar
http://guerragroup.com/camshaft_help.htm
Old 08-07-2012, 04:47 PM
Ls1nutZ28's Avatar
thanks I fig thats what everyone would say. I just sent my payment to pat and sent the form, how long does it normally take for him to get back to you?
Old 08-07-2012, 06:08 PM
LS6
LS6's Avatar
There are cam's that made solid 500rwhp or over, but you have to decide to which intake you will use (EFI Stock LS3, EFI Ported LS3, EFI GM signle Plane, EFI Edelbrock signle plane, EFI Edelbrock dual plane, EFI Holly signle plane, EFI Holly dual plane)
-Patrick G.
-Spinmonster (In Corvette Forum).
-RPM.
-LG.
-Thunder racing.
-Cam motion.
From reading the LS1tech forums, there are many posts about Patrick, PRM, Thunder racing and LG cams doing minimum of 470 rwhp and up to as 517 rwhp with 6.0 Liters engine.
By the way these LS3 heads love compression (CR).
As advised, try to approach Patrick G, RPM, LG and Thunder racing and they will sure help you in what you are looking for to achieve your goals.
I hope this will help
Old 08-07-2012, 08:21 PM
PROMODLSX's Avatar
Thanks everyone I just did the form and going to wait and see what Pat has to say. kinda wondering what I would gain from milling the heads to get it around 11.5 (CR)
Old 08-07-2012, 09:55 PM
Burrhos's Avatar
Pat G cam here in my vette.
EPS 230/238 .600/.615
Old 08-07-2012, 10:34 PM
SLOW SEDAN's Avatar
I ran a 235/242 with milled heads, 3600 stall and 3.70 gears, ran like a champ!
Old 08-07-2012, 10:50 PM
6D9 Matt's Avatar
Another vote for Pat G... seems to be a very popular option with the LS guys.
Old 08-07-2012, 11:22 PM
C5natie's Avatar
If its a stock crate motor I would go with Texas Speeds 231/236 cam. Thats what I have in my stock LS3 and Im very happy so far. Great torque at low rpms and just pulls like a train up top. Seen a couple C6's running high 10's with this cam, cam only too. I got a 114lsa yet it still has a nice lopey idle. A 111 or 112 might be what you want. This cam is a good size cam for an LS3 due to the tight ptv clearance due to the huge intake valves. With some of the other bigger cams youll be cutting it close...if youre not touching the bottom end.
Old 08-08-2012, 01:44 AM
jrane's Avatar
Another Vote for Pat G!!! Had him spec me plenty of cams, and never once disappointed
Old 08-09-2012, 12:16 AM
C5natie's Avatar
Ive only heard good things about Pat G but personally I dont agree with paying $25 for a service that any good shop does for free. Of course people are gonna be happy because theyre gonna feel a difference in performance with a good cam. Unless the money goes towards the purchase of the cam if you buy it from him, then maybe. JMO.
Old 08-09-2012, 04:50 AM
87silverbullet's Avatar
Don't forget about Geoff Skinner@ EPS either. Pat G has worked with him on a few things in the past regarding cam stuff. Pat G sometimes uses Geoff's proprietary lobes on his custom spec'd cams
Old 08-09-2012, 07:35 AM
Fbodyjunkie06's Avatar
I have spec'd several LS3 cams and many other cathedral port cams with good results. I just spec'd a stock stall G8 cam with a L76 yesterday for a friend of mine's wife. Should do really well.
What do you want to do with the car other than it being a driver? HP goal, mph goal or E.T. goal?
I can get you in the right ball park also if you would like.
Old 08-09-2012, 05:02 PM
ChargedCamaro's Avatar
Lethal Racing "Night Fury" Cam
Old 08-09-2012, 06:59 PM
Dyno Junkie's Avatar
Off the shelf Comp Cam 231 239 .617 .624 113 in a crate LS3, good enough to run 11.22 in the quarter in a 3880lb Monaro (GTO).
Old 08-09-2012, 07:41 PM
1989GTA's Avatar
"Off the shelf Comp Cam 231 239 .617 .624 113 in a crate LS3, good enough to run 11.22 in the quarter in a 3880lb Monaro "
Very good times. What mods were done besides the camshaft?
Old 08-10-2012, 12:19 AM
Engine,
Double row timing chain
Hardened pushrods
Valve springs & retainers
90mm throttle body
Ram Jet OTRCAI
WA Performance MAFLESS tune
25% under drive
1 7/8" into 3" headers
3" section to 3" cats
Twin 2 1/2" exhaust system
Gearbox,
Stock 4L60E
Allfast 9 1/2" convertor
Diff,
4.1:1 diff gears
Wheels
Stock 18" x 8"
Tyres
Front 225/40/18
Rear 265/40/18 Mickey Thompson
As it is sitting on the rev limiter some 40 yards before the line I am looking at trying 274/45/18 M&H tyres soon.
The last pass I made I let the car shift into 4th gear which lifted the speed up from previous 120.xxmph to a little over 121mph so it may have enough power to use the taller tyre.
Old 08-10-2012, 02:02 AM
2002camaroSS's Avatar
Dam! Nice numbers and I see the car runs good at the track too!
Quick Reply: whats the best LS3 cam ?
