Max effort LS7 Cam suggestions needed
Old 04-04-2013, 12:02 AM
wesam's Avatar
Default Max effort LS7 Cam suggestions needed
I want to order cam for 2012 boltons Z06 intended for road racing
drivebillity is not an issue
There are some cams in my minds but don't know which to choose :
Black mamba, Black widow, TSP LS7R, LG G7X5
Any help will be appreciated
Old 04-04-2013, 06:37 AM
Orange Juice's Avatar
I would talk to LG, or Katech, builders that work a lot with track cars.
Old 04-04-2013, 07:16 AM
HioSSilver's Avatar
GM makes a nasty stage 3 cam that might fit your needs. If you don't want to change valve springs you could use their stage 2 cam. Hotrod did a full test on them sometime back.
Old 04-04-2013, 08:19 AM
Brian Tooley Racing's Avatar
I've got a buddy who set the C6 Z06 H/C record last year with a QM Black Widow. I spun the cam on my Cam Pro and was shocked to see the peak velocity was lower than a stock LS9 intake opening ramp! That means it would be easy on parts, which is very important in a road race car. He used my Platinum springs with that cam.
Old 04-04-2013, 08:43 AM
texas94z's Avatar
How much power did your buddy put down?
BTW your parts are awesome.
Old 04-04-2013, 09:36 AM
He put down around 600 rwhp on a Mustang dyno, it was first tuned on James Short's Dyno Dynamics dyno but I can't remember the numbers from it. He ran as fast as 141 MPH and ran as quick as 9.93
Thanks for the kind words, we try very hard!
Old 04-04-2013, 08:11 PM
Super Hulk Smash
JakeFusion's Avatar
Quality Motorsports is very well renowned with the LS7s.
QM600, Black Mamba, Black Widow. All solid profiles.
Old 04-05-2013, 04:42 PM
studderin's Avatar
Id see what ed Curtis says for a cam, hes stuff makes great power all the time.
Old 04-06-2013, 01:57 AM
gto_ua's Avatar
I have curtis 256/268 cam in my LS7 and happy with it.
you should run 25x/26x 115lsa cam
Old 04-07-2013, 09:32 AM
We pulled the Black Widow out of my buddies car and installed something a little more aggressive. He reset the C6 Z06 H/C record yesterday running 9.86 @ 140.8 at 2000 ft D/A and he was .04 off his best 60'. With better air and a better 60' he's hoping for 9.70's. Cam was in the 24X/26X range.
Old 04-19-2013, 08:04 PM
Turbo2L's Avatar
Does your friend have a build thread anywhere?
Old 04-19-2013, 08:37 PM
He posted over on Corvette forum, I'll be glad to answer any questions you might have. He had BTR/WCCH heads and a BTR ported Fast and TB, RXT clutch and drag radials. He sprayed it last weekend and ran 155 MPH in the 1/4.
Old 04-20-2013, 09:52 AM
Moderator
John B's Avatar
If you don't mind a solid roller you can use a proven performer like mine https://ls1tech.com/forums/dynamomet...92-octane.html
Old 05-07-2013, 05:34 PM
James@ShorTuning's Avatar
Kinda late to the party but it ended up at 519rwhp in the state it was when it trapped 141mph.
Old 05-07-2013, 11:30 PM
WVhuggerSS's Avatar
And the car is a six speed right? Saw the video over on ky horsepower, awesome performing car!
Old 05-08-2013, 08:09 AM
Yep, stock T56 tranny. He sprayed it and ran 8.82 @ 161 to set the Corvette 6 speed record, previous record was a 9.24
Old 05-08-2013, 05:54 PM
Cam only Z06 in Sweden getting it done with 606 RWHP!
Old 05-09-2013, 02:37 PM
Sales@Tick's Avatar
Some highly respected people posting in this thread for sure with lots of credentials to back them up, but I will throw our name into the hat with our LS7 Polluter camshaft and soon to be released LS7 Saturday Night Special Stage 3 TorqueMAX camshaft.
Old 05-09-2013, 03:23 PM
hymey's Avatar
My 434ci LS7 mast heads has a 273 289 110 solid roller, very aggressive cam, awesome response , idle nice, peaked at 7200, made 803hp without to much effort, had no vac pump-very low tension rings, collectors had a 3 inch flange welded on 3.5 collector, oil was to high viscousity, with thinner oil , spacer, collectors done and the vac pump and tuning it would go 850 easily. I have a new cam 285-300-114, everything inc port cross section wants a 8000 rpm peak, with wider lobe sep it will peak this late, am hoping close to 900 HP from it.
IMO from what I have learnt with big engines/big heads on engine dyno, run as much comp as you can, and as much cam. everytime I go up in cam say 250 to 260 there is another 20 and some. These motors because of the large cross sections come alive with more cam and comp. stick to solid roller, much faster seat to seat gives better drivability , high 200 numbers make a lot of power, get best of both worlds with solid roller, keep it on 114LSA. 250@50 is a small cam in a 427ci, its a biggish cam for a 364ci, but even then 266 is nice for small cubes. 270@50 is good high avg power cam for 400ci plus. Id use my old cam and keep it in a 408. 280@50 is a good max effort cam for 427-454, they love it, seen so many big engines engine dynoed and it is where it starts to happen., Remember hydro roller equivalent is like 10 deg less then solid.
Old 05-09-2013, 06:38 PM
Sales@Tick's Avatar
What kind of springs are you guys running on these solid roller set-ups with stock casting heads?
Quick Reply: Max effort LS7 Cam suggestions needed
