Every engine builder should have one of these
#81
When youre dealing with oil leaks, especially on the rear cover, youll be kicking yourself over that 10bucks.
I just bought a full set and will be using them constantly. I recently started working at a shop and will be assembling many LS motors. So these will come in quite handy. Customers dont like oil leaks.
Btw fellas, the saccity dogbone is pretty badass too. Bought one for my sons 408.
Christian,
Thanks for the products and fast shipping.
#82
Hi maroonls1z,
The problem we found with using the seal to align the cover is the seal lips flex and don't keep the cover centered when you tighten the bolts down. Especially when tightening the two oil pan bolts, they pull the cover down farther then it needs to go and will cause misalignment of the seal. GM even recommends using the expensive Kent Moore tool to align the cover. The new seal does come prelubed, we only put oil on the tool O-ring.
Hope that helps.
Thank you,
Christian
Hope that helps.
Thank you,
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
#84
Do you live in a cold climate? Has your Align-It tool become stuck on the back of your crankshaft and is too oily to get a good grip on? Are conventional caveman methods of hitting and prying on it not working?
Don't worry!
Just grab an old accessory drive belt and wrap it around the tool, then twist just like you would with a pickle jar. Problem solved!
Because Canada.
I really do like having these SacCityCorvette tools and the Kent Moore kit when assembling an engine.
Don't worry!
Because Canada.
#85
Thanks for the tip and the kind words mOtOrHeAd.
Our latest Rear Main Tools have a O-ring on the inside of the tool that should eliminate issues with cold weather. Does yours have a O-ring on the inside part of the tool or just the outer O-ring?
Merry Christmas!
Christian
Merry Christmas!
Christian
__________________
#86
If your doing the Rear Main don't forget to install one of our Precision Billet Barbells/Oil Diverter while you in there. It keeps unfiltered oil out and improves oil flow! Check out the videos at the link below. Also check our other oil system improvement products.
http://www.saccitycorvette.com/Billet-BarBell.html
__________________
#87
If you need one of our AlignIt Tools we have them ready to ship same day!
http://www.saccitycorvette.com/AlignItTools.html
__________________
#88
Just ordered a front/rear kit and a barbell! They look great. Trying to build a new 700whp forged LSA here and I don't want leaking seals or crap sneaking past the stock barbell lol. Even the new one in my new block looks like cheap junk. You would think with a $2500 block and such an expensive engine (the LSA/LS9 anyway) that you would get more than a piece of plastic.
Thanks
Thanks
#89
Thanks for your order aero!
Ya, the stock barbell isn't even completely round if you mic it. So it doesn't seal very well.
Thanks
Christian
Thanks
Christian
__________________
#91
Thank you for your business 243, and the kind words!
Christian
Christian
__________________
#93
Thank you David for your business, we really appreciate it.
We will get it right out to you.
Christian
Christian
__________________
#96
Thank you BOLO for the kind words and your Business!
Christian
Christian
__________________
#97
Hi,
If you have your engine torn down, doing a rear main seal or have your pan off you might be interest in these oil system improvement items.
You can find how they work to improve your system here.
Thanks
Christian
Thanks
Christian
__________________
#98
Same Day Shipping!
__________________
#99
Hi all!
If you're doing an engine build or cam swap, these tools will help prevent premature seal wear and leaks.
https://www.saccitycorvette.com/AlignItTools.html
Also, while doing that build or rear main seal, its a good time to install our Billet Barbell to help keep unfiltered oil out of your bearings and lifters.
Check out our Billet Oil System Improvement Parts.
https://www.saccitycorvette.com/OilS...provement.html
Thank you,
Christian
Thank you,
Christian
__________________
#100
We hope everyone is doing well and staying safe during this crazy time of the virus.
Just wanted to let you know, while we are practicing the virus safety precautions, we still have our same day shipping of our products.
Stay safe and let’s get through this!
Christian
SacCityCorvette
Christian
SacCityCorvette
__________________
