oil pan and f body problem
Old 07-28-2013, 06:14 PM
ws6guy27's Avatar
Default oil pan and f body problem
Have a erl ls2 with a stock f body oil pan.. out the cut windage tray exposing the 1 amd 2 rods and oil pump. Put the pickuo and oil pan on with gasket just snug to check clearances amd it hits the oil pan amd stops. Any ideas or experiences on this? Can I just dejt in the pan where it knicked the pan off the rod bolt.. I dont wanna space the oil oan.. then it wont seal right. Iv spaced yhe windage tray but agn the rod bolt hits the pan and stops.. anyway t o dent pan or somthing dor it to clear??
Old 07-28-2013, 06:29 PM
LPE 403's Avatar
Seriously dude...spell check or proof read before you post. Geezus....
Old 07-28-2013, 06:37 PM
ws6guy27's Avatar
Sorry typing on a phone. But I have a shortened windage tray exposing the number 1 and 2 rods and oil pump. Once everything is together pan on and everything. As I rotate the internals to check clearances. The number 2 rod bolt hits the pan. Using a stock f body oil pan off a 2000 ws6
Old 07-28-2013, 06:55 PM
LPE 403's Avatar
lol, better...
my first thought is an aftermarket oil pan but cant recall the height/depth difference between stock and non that far forward. its pretty tight up there relative to the k-member.
Old 07-28-2013, 07:21 PM
ws6guy27's Avatar
Trying to avoid aftermarket pan. Want stay with stock pan...
Old 07-28-2013, 07:25 PM
01 Vert ws6's Avatar
are you sure its hitting the pan and not the windage tray
Old 07-28-2013, 08:07 PM
ws6guy27's Avatar
Yes im sure. The windage tray has been cut short to clear the oil pan so it leaves the number 1 and 2 rod bolts exposed. (From my old ls6) so when I put the windage tray on and bolt the pan on.. rotate to check clearances. It hits the pan. It put a knick in the pan
Old 07-28-2013, 08:10 PM
Gray86hatch's Avatar
The stock pan has issues with oil control. Pick up tube placement is bad. The Moroso alum pan is really nice and fixes these issues.
Tim
Old 07-28-2013, 08:24 PM
ws6guy27's Avatar
How does it have oil control issues? Had good psi cold and hot in my ls6?... what does it cost for a new moroso pan? Id like keep the stock pan. If possible.. guess I didnt know/had issues before.
Quick Reply: oil pan and f body problem
