Has anyone had any problems with VVT?
Old 10-02-2013, 07:56 PM
y5mgisi's Avatar
Default Has anyone had any problems with VVT?
Or is it fairly fail safe? On a stock motor, if the phaser fails, will the pistons hit the valves? Or will drivability be the only harm done? Trying to decide if i should do a VVT delete when i do my DOD delete.
Speaking of, I can keep VVT and delete DOD right?
Old 10-02-2013, 08:14 PM
1989GTA's Avatar
"Speaking of, I can keep VVT and delete DOD right?"
Anyone building a performance motor that is the first thing done. Regarding VVT I am sure there have been some problems like everything else but from what I have seen and read it is very reliable. I am keeping it on my motor. One of the best things about VVT is that you can phase the camshaft to provide the best power through out the rpm range.
Old 10-02-2013, 08:23 PM
y5mgisi's Avatar
Good to hear! Yea i really like it! I fell like it helps considerably with the 5.3's lack of low end grunt. I understand the phaser (sp?) might fail, but it does seem like it itself isnt common for having problems correct?
Old 10-02-2013, 09:53 PM
1989GTA's Avatar
I am sure there have been some phasers that have failed but I would say it is uncommon. There are a lot of vehicles out there with VVT and you don't hear about it.
Old 10-04-2013, 03:39 PM
LS1Tech Sponsor
Slowhawk's Avatar
I've seen 4 failures personally.
Old 10-04-2013, 04:54 PM
y5mgisi's Avatar
When the failures happen, is there any catostrophic damage? Or does the phase not phase?
Old 10-05-2013, 04:29 PM
LongIsland63SS409's Avatar
Curious what failures you have seen?
Mike
Old 10-09-2013, 09:57 PM
y5mgisi's Avatar
Bump?
Old 10-10-2013, 08:05 PM
Ofnaman's Avatar
I am a GM technician and coming from the repair side of things, I've never seen it fail on an LS engine. The only issues I've seen is lifter failure causing cam damage (AFM engines and non AFM engines). I reuse the vvt actuator on those engines and have not had any issues. Keep in mind, these are stock engines in stock vehicles.
Old 10-10-2013, 11:15 PM
y5mgisi's Avatar
Good to know.
Quick Reply: Has anyone had any problems with VVT?
