ls2 402
Old 01-10-2014, 07:53 PM
63falcon's Avatar
Default ls2 402
Question I have is .006 acceptable piston to wall clearance in a turbo motor that will see alot of street use? Pistons are mahle 2618 forged. Thanks
Old 01-11-2014, 10:22 AM
FastKat's Avatar
Not sure, but you should have received info on piston to wall clearance from the piston manufacturer?
Old 01-11-2014, 11:09 AM
KCS
Moderator
KCS's Avatar
That's pretty excessive to me, I'd like to see more like .0035-.004". That much clearance might cause some piston slap when the engine is cold.
Old 01-11-2014, 12:10 PM
63falcon's Avatar
I know its a bit excessive problem is its the way I received it only question now is to start over or run it. Im ok with a little cold piston rattle but I would prefer not to have a diesel.
Old 01-11-2014, 02:27 PM
KCS
Moderator
KCS's Avatar
Personally, I wouldn't accept that for a street car. I'd fix it or run a different shortblock altogether. I don't think it will make a horrible amount of racket, but then again, it could. What I can tell you is that it won't cause it to blow up or anything.
Old 01-11-2014, 03:08 PM
63falcon's Avatar
Hmm have some thinking to do.
Old 01-11-2014, 05:16 PM
Briou's Avatar
anyway you can return the pistons and get the correct ones? If not I would sell those and go with a better fitting piston...I would rather do it right the first time and lose a little money then do it multiple times
Old 01-11-2014, 05:33 PM
63falcon's Avatar
Not sure guess I have some calls to make.
Quick Reply: ls2 402
