ls3 cam stock spec
Old 02-20-2014, 08:13 AM
ly6rancing's Avatar
Angry ls3 cam stock spec
I have a cam and not that engine?
tell me that is 6.2l camaro I want to be sure if this is true
have these numbers 2273 3 17 07344, can you help me please ... and thank you very much
Old 02-20-2014, 02:08 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
I'm kind of having a hard time following your post but if you are asking what the stock LS3 cam specs are then it is 204/211 .551/.525 120° LSA with 5° of retard in it.
Lonnie
Old 02-20-2014, 07:14 PM
ly6rancing's Avatar
sorry if I'm not expressing myself from Venezuela and not speak much English.
I know the spec are those that you say, what you do not know if it is a cam ls3 stock .....
I'm doing a project with a Ly6 with stock ls3 cam and 10.66 r / c l92 ported ....
Old 02-20-2014, 08:48 PM
jegten's Avatar
Si me permites, creo que Lonnie le dijo que esas son las especificaciones del cam (arbol de leba) que viene de fabrica en los LS3 (stock ls3).
Old 02-21-2014, 04:44 AM
Iam Broke's Avatar
I believe he wants to know if the part numbers he posted are an LS3 cam.
Old 02-21-2014, 11:41 AM
jegten's Avatar
^ Exactly, and that is what I responded to him. Now, if Lonnie wasn't going by that number, then...
Here are the two part numbers associated with the stock LS3 cam and specs-
ls3: New #12623063. Old #12603844
204/211 .551/.525 117lsa
ly6rancing- no encontre informacion alguna con el numero de parte que proveiste. Como vez, los numeros de parte que encontre no semejan al que nos diste. Tendras otro numero? Gracias.
Old 02-27-2014, 09:22 PM
ly6rancing's Avatar
muchachos los felicitos por esta pagina me ha servido de mucha ayuda y soy fanatico a ls1tech,a lo que me refiero es que tengo esta leva y si se cuales son los numeros de partes de las 2 levas que hay de ls3, pero en mi leva no le veo el numero de parte solo veo que en donde tiene el codigo de barra estan estos numeros 2273 3 17 07344 y quisiera saber que leva es esta ya que quiero hacer un LY6 6.0L con leva de lS3 y darle mas r/c..........muchas gracias
Old 02-27-2014, 11:09 PM
DietCoke's Avatar
I have an LS3 cam out of my LS3 right here from a 2011 camaro. the numbers on it are:
3063
S 07
0208
He is referring to the laser etched numbers on the backside of the cam. There is no part number to be found.
Old 02-28-2014, 02:11 PM
jegten's Avatar
ese numero que nos das, dices que esta con el codigo de barra? donde vez ese codigo de barra?
otra pregunta, el numero que nos das esta embosado en uno de los extremos del leva? El numero que te ha dado DietCoke es el que esta embosado en uno de los extremos del cam que tiene el en sus manos, pero es mas corto que el tuyo.
A ver si pedemos descifrar esto! lol
3063
S 07
0208
He is talking about a bar code number he is seeing somewhere. I asked him where is that bar code he is seeing. Somehow, we'll figure this out with him.
Old 03-02-2014, 03:31 PM
ly6rancing's Avatar
si amigos a ese numero me refiero al que esta al extremo de la leva... el que dice el amigo dietcoke... ya se que no es de camaro 2011 gracias al amigo dietcoke....
amigo jegten aqui dejo tus respuestas y gracias amigo.....
ya se que saben del numero que hablo, ya que las levas originales no traen numero de parte la leva original del motor mio que le quite es un LY6 6.0L es:
2274
1 13
08301
Attached Thumbnails ls3 cam stock spec-img-20140205-00740.jpg   ls3 cam stock spec-img-20140227-00771.jpg
The following users liked this post:
Daniel Bernal (09-01-2019)
Old 03-04-2014, 12:40 PM
jegten's Avatar
DietCoke-you were right, he was asking about the number laser edged.
great setup, btw. I was excited about your numbers since I have a somewhat similar setup, but then saw you are on e85. I am on pump.
Bueno compay, he estado buscando sin resultado. Sin saber de que carro salio esa leva y aparte de que haya alguien con un cam con ese numero y sabiendo de que carro vino, no creo que podamos saber los detalles especificos que estamos buscando, lastimosamente.
Algo que podrias hacer es figurar el 'lift' del cam ese y asi compararlo con los specs del ls3 cam para ver si son iguales. Por lo menos de da una idea. Tambien, si tienen un taller que tenga un 'cam doctor' de seguro que si te dan los detalles.
Cam lift- uso un micrometro, mide la distancia en pulgadas mas grande de una de las levas, resta la distancia mas pequenia de una de las levas, la diferencia la multiplicas por el rocker arm ratio, 1.7, dandote el 'lift' total. Hazlo con dos levas consecutivas, intake and exhaust. Y si los valores son .551/.525, voila! Saludos!
Old 03-07-2014, 08:48 AM
ly6rancing's Avatar
Smile
Ok amigo muchas gracias por su ayuda estare publicando mis resultados con mi motor... que tengan un buen dia....exelente pagina.....
Old 03-10-2014, 02:20 PM
jegten's Avatar
De nada, vale, con mucho gusto! Suerte y esperando los resultados!
Old 09-01-2019, 01:25 AM
Daniel Bernal's Avatar
2274
1 13
08301
Hi... I'm New Please bear with me I was told that this cam was from an LS3 & it has these laser engraving numbers 3063 S 11 1131
Quick Reply: ls3 cam stock spec
