BEST flowing heads for 4.030 bore........?
390ci LQ9
I was thinking of using ported LS3 intake and NW 92mm TB. But all the heads I find in searches seem to need a 4.06" bore or larger.......
Like the TFS 255's or L92 heads......
What's the best ones to buy.......?
Thanks.....
Thanks.....
MASS seller approved
Ls3 heads with exhaust ports cleaned up. I can tell you from experience Trick Flows are best for 408 or more cubes. Dont get hung up on flow numbers. Bigger is not always better. Just consider fast n/a ls3 camaro, rhinos, runs 10.45 with cleaned up ls3 heads and outruns some with TFs or similar heads. A buddy made the expense for some TFs, and ran same ets, lost bottom end, but increased top end speed...same et though...all for 2500 bucks...
As for needing a 4.065 to effectively run ls3 heads...thats false...plenty stock bore lq9s and ls2s with ls3 or l92 heads including me...
In that 390 cube motor id love to see a comp 235 243, 620 624, 113+2 cam with ls3 heads cleaned up or ported exhausts, at least 1 7/8 but preferably 2 headers, at least 4k stall and 3.91 stall...
