What piston for TFS GenX255 head @ 4/4.005/4.030 Bore?
Old 10-08-2014, 12:55 PM
Petey-Pop-383's Avatar
Default What piston for TFS GenX255 head @ 4/4.005/4.030 Bore?
What piston are guys using at 4/4.005/4.030 bore with TFS GenX255 heads?
With the 12° valve angle the it will have to have LS7 valve pockets.
Wiseco/JE/Diamond it will be a custom piston.
Is there a shelf piston available?
Old 10-08-2014, 05:46 PM
lil john's Avatar
Yes they have off the shelf pistons 4 U.
Find out which bore size you want 2 go with. Then call but these JE's are really really light.
Old 10-08-2014, 05:53 PM
lil john's Avatar
4.030 bore min. is required but smaller valves could be used for anything less than 4.030 bore.
Old 10-09-2014, 08:13 AM
Trickflows website notes 4.000" as the smallest bore diameter.
Old 10-09-2014, 08:16 AM
I want to use these heads on a 4" stroke, iron 6.0L block nitrous motor.
That is not the best if 4.030 is the smallest you can use.
Old 10-09-2014, 08:47 AM
lil john's Avatar
Never knew that, thought 4.030.
Call and see its early about your pistons. They have either piston for your set-up. I have a part number for the JE asymmetrical piston 4.030 bore. part#311979 Tuff skirt coating them will set you bac 175.oo.
Old 10-09-2014, 10:14 AM
What size of nitrous shot would you be comfortable using with that piston?
Old 10-09-2014, 10:22 AM
lil john's Avatar
Cant say cause I never asked. Just call them. I will call 4 you and get the info from my man @ JE
Old 10-09-2014, 10:27 AM
LivernoisMotorsports's Avatar
You just bought some killer cylinder heads. Maybe the question is why wouldn't you design a piston for what you are doing? Anything off the shelf is most likely making some kind of a compromise vs what's optimal for your goals/combo.
Old 10-09-2014, 10:34 AM
lil john's Avatar
Was told that you may be able 2 get away with a 200shot. There website list any combo from what I was told. Didn't reach Henry.
Above statement so true but with added cost
Old 10-09-2014, 10:56 AM
lil john - thanks for checking.
Livernois - I haven't bought anything yet, in the planning stage...
Old 10-09-2014, 04:49 PM
"Petey-Pop-383"
If your in the planning stages feel free to pm or call if you are looking for some help/advise that's what were here for.
Quick Reply: What piston for TFS GenX255 head @ 4/4.005/4.030 Bore?
