Timing tensioner and oil pump o ring questions
Old 10-16-2014, 12:30 PM
jimmyg's Avatar
Default Timing tensioner and oil pump o ring questions
Ok so build is 2010 ly6 with 60k keeping vvt
1 want to replace tensioner can I use ls2 tensioner with vvt?
2 using holley 302-2 pan came with blue o ring. Use this or new orange one like one in motor
3allready put cam in was told chain would be fine but now have doubts reading horror story's on here thinking of new katech chain .will I need to get another valve? I installed the first one all ready .if u know please chime in so I don't end up another horror story thanks
Old 10-20-2014, 12:31 PM
Briou's Avatar
I would opt for a new chain for sure...not really sure what valve you are talking about...if it is the single cam bolt/valve, then yes...It is a tty style bolt so you need a new one every time you loosen it after torquing it to spec...
Old 10-20-2014, 06:20 PM
jimmyg's Avatar
Ordered new chain, tensioner , valve/cam bolt and orange o ring for oil pump went with ls3 tensioner because I don't think u can use ls2 style damper with vvt
Old 10-20-2014, 07:10 PM
Briou's Avatar
Yeah I wasn't sure on the tensioner...for the oil pick up o-ring I think I used the one that came with my melling oil pump, so I didn't use either of the ones that came with my holley pan, but the way I decided on that was trying all of the ones I had with the pan and with the pump, and just picked the one that seemed like it had the best seal....What is the engine going in just out of curiosity?
Old 10-21-2014, 05:13 PM
jimmyg's Avatar
83 cutlass ly6/ 4l80/ strange s60 the car was owned by a gm fanatic . It's all original it was stored in a barn for 20 years .look in my pics and u can see it .I'm not that computer savvy I don't know how to post a pic in thread .what's yours going in?
Old 10-21-2014, 05:18 PM
Briou's Avatar
Mine is going in a 1970 chevelle...Wish I could use the revised holley pan to get the tie rod clearance, but I can't due to having a 4.125" stroke crank...
Old 10-21-2014, 07:29 PM
jimmyg's Avatar
U can but u have to mod the pan People are doing it I saw a discussion about this in the holley swap preview for g body there is a guy on here who is an engineer for holley he was talking about it
Old 10-22-2014, 10:10 AM
Briou's Avatar
Yeah that was just one more thing I didn't want to mess with...I only loose about 1/8th of a turn of the steering wheel, so I'm not that concerned with it...I had enough trouble clearancing the windage tray
Old 10-22-2014, 07:00 PM
jimmyg's Avatar
The mast motorsports pan have u looked at that? Very close to 302-2 pan but ok for 4.125 stroke
Old 10-22-2014, 07:05 PM
jimmyg's Avatar
Me I'm building a vvt motor can't find anyone to tune it
Old 10-23-2014, 12:27 AM
Briou's Avatar
I hadn't looked at the mast pan before...I got the holley installed now, and it won't be coming off the engine unless something goes boom...I have heard of people having issues finding a tuner for the VVT stuff...
Old 10-23-2014, 09:13 PM
jimmyg's Avatar
I going to go with mast motorsports electronics they sell this combo so it comes pre
Calebrated I guess it is my only option. the only good news is it should be over 500 hp they got 509 with truck intake I'm going with ls3 intake 42lb injectors 17/8 long tubes so hopefully it should work out I checked out your build thread nice car! I love chevells have u ever seen ss Shaun. On u tube? Check it out one of the nicest chevells I have ever seen he street races it
Old 10-23-2014, 11:11 PM
Briou's Avatar
Hadn't seen it before...I'll go check it out...
Quick Reply: Timing tensioner and oil pump o ring questions
