Injector adapter solutions LS1/LS6 - LS2/LS7
Old 04-05-2006, 10:32 AM
LS1TECH Sponsor
Katech_Jason's Avatar
Default Injector adapter solutions LS1/LS6 - LS2/LS7
Introducing a solution to your injector swapping problems
KAT-A4756 - For using a LS1/LS6 injector with a LS2/LS7 harness
KAT-A4757 - For using a LS2 injector with a LS1/LS6 harness
KAT-A4758 - For using a LS7 injector with a LS1/LS6 harness
Each kit is $99.95 for a set of 8
Old 04-05-2006, 11:44 AM
Rollin Black's Avatar
Great product Jason.
Performance/reliability Question - So costs aside - would it be better for me to install LS1 size injectors onto my LS7 top end with your spacer kit....or get your wiring adapters KAT-A4757 and use the LS7 injectors? The LS1 injectors are 42#.
Thanks, Perry
Old 04-05-2006, 12:23 PM
LS1TECH Sponsor
Thanks, Perry
If you dont mind the rail being spaced an extra inch go with the spacers and LS1 injectors. If you want to keep the LS7 injectors you can go with the KAT-A4758.
Edit: Slight change to the KAT-A4757 and they are now KAT-A4758 for LS7.
Old 04-05-2006, 11:30 PM
Thanks for the info Jason.
I will stick with the spacer kit and LS1 injectors. My new LS-7 spacer kit arrived today, thanks again!!!
Perry
Old 04-06-2006, 05:43 PM
6 Second Club Moderator
LASTLS1's Avatar
Perry
SPACER KIT???? From who? Thanks
Old 04-06-2006, 05:47 PM
I got the LS7 spacer kit from Jason at Katech.
Thanks, Perry
Old 04-21-2006, 09:16 AM
cablebandit's Avatar
will one of those harnesses work for truck guys wanting to go to ls1 injectors?
Old 04-22-2006, 09:04 AM
Restricted User
98Z28CobraKiller's Avatar
Are those new LS7 injectors the same as the ones that are on the 03-04 Cobra? I had a buddy give me his old ones but I couldn't find an adapter to make them work with my LS1 harness.
Old 04-22-2006, 06:13 PM
lowyukon's Avatar
__________________
I want to know too.
Old 05-03-2006, 02:40 AM
Ferocity02's Avatar
Jason, are these adapter wires something the average joe can make at home? I'm thinking I just need the connectors and the wire and some time to make them right? Or is there more to it? I'd figure I'd try to save some money.
Old 05-03-2006, 08:01 AM
LS1TECH Sponsor
You can make them at home if you know how the terminals work.
Old 06-10-2006, 10:52 AM
caindo's Avatar
I cant find the part number KAT-A4756 on your site jason?
Old 06-10-2006, 05:29 PM
LS1TECH Sponsor
It's no on there because we haven't updated the site much. We plan on updating the site a lot later this year with e-commerce.
Old 06-12-2006, 05:12 PM
caindo's Avatar
jason, i need these pretty bad, and a set of ls1 o-rings, by friday to AZ. is it possible ?
Old 06-13-2006, 05:46 PM
LS1TECH Sponsor
Call me tomorrow. We can 2 day air or overnight.
Old 07-07-2006, 06:24 PM
chris01hd's Avatar
Im looking for truck adapters to LS1 style, can you point me in the right direction?
Old 07-07-2006, 06:25 PM
LS1TECH Sponsor
I haven't seen them.
Old 07-08-2006, 03:48 PM
White_Hawk's Avatar
I have a set of injectors from a 03 Cobra that have the new style connector. I used them on my 04 GTP which I have since gotten rid of. Can I use these on my LS1 now? I think they are 39 lbs or so. Here is a pic. It would be nice to save some coin by just getting the adapters.
-Geoff
Attached Thumbnails Injector adapter solutions LS1/LS6 - LS2/LS7-100_1648.jpg
Old 07-08-2006, 09:37 PM
datsbad's Avatar
I am pretty sure you can also get these on ebay for about $ 59 , just FYI if your trying to save some cash
Old 07-08-2006, 09:42 PM
LS1TECH Sponsor
-Geoff
If they are the same height and o-ring size then I guess so.
Quick Reply: Injector adapter solutions LS1/LS6 - LS2/LS7
