Do I need coolant crossover pipe ?
Doing a 402 alum. block buildup. AFR heads slp shortblock. fast 90/90 . The fast T-body doesnt have a tube on bottom for the coolant line frome the crossover pipe. Can there be plugs installed in the front coolant holes as in the rear ones ? or does this pipe need to be in place and block off the tube coming off pipe ?
Thanks
Ron H.
Thanks
Ron H.
Originally Posted by ls1408cp
run the crossover to the radiator. you need it
Thanks
Ron H.
