Best compression for 408.
Old 02-25-2007, 07:51 PM
vettefever17's Avatar
Default Best compression for 408.
Okay my final stages are closing in on my 408 plan before I buy the parts. What would be the best compression ratio to run for the street and normal gas octane ratings. I want to squeeze all the power I can out of the engine, and still be able to run regular pump gas. I need to know what cc piston, gasket, and cc chamber on my heads. Please give me some insite... Head I am using are the AFR LS1 225cc heads with a choice of 62 amd 72cc chambers. Also, the piston options I have are -12,-15,-2,-10.
Old 02-25-2007, 07:54 PM
getusum's Avatar
look at my sig......mine is made to run on motor, and the laughing gas...pretty safe
Old 02-25-2007, 08:50 PM
LS1Tech Sponsor
Slowhawk's Avatar
It depends on the Cam also but I would start with -2cc pistons,72cc AFR's,GM gaskets and a mid to high 240 Cam.
Old 02-25-2007, 09:35 PM
See thats just it, I have no idea what cam to go with. I want something like mentioned above. Streetable, every little bit of horsepower squeezed out of it.
Old 02-25-2007, 10:37 PM
skipperbisket's Avatar
11.5:1 for a 408 in a street car should make some sweet power with the right heads/cam setup. -2 piston with a smaller chamber should do the trick.
btw, i have a great cam for a 408 street motor. 243/246 .632 112 pm me if you're interested in it.
Old 02-25-2007, 11:08 PM
What size gasket and head chamber makes close to that?
Old 02-27-2007, 01:15 AM
That's what she said...
TheBlurLS1's Avatar
http://www.rbracing-rsr.com/compstaticcalc.html
That should help you out. You can enter different combos and see how they turn out. Find out the deck height of the pistons, then you can figure out what kinda quench to run, then pick gaskets. Then you can delect chamber CC and piston CC to hit the right Static CR.
Old 02-27-2007, 06:19 AM
beardWS6's Avatar
Love my cam. Car made awsome power for a auto. I`m running 11.1 with my big cam. Love it!!
Old 02-27-2007, 08:57 AM
Restricted User
2001 Pewter WS6's Avatar
I have ETP 225 heads 64cc
Diamond -2cc pistons
Comp 244/248 cam
Cometic Gaskets .042
12.1:1 CR
and I run on Sunoco 93
Old 02-27-2007, 04:34 PM
Badls6SS's Avatar
I'm right around 11.9:1 and the rest of my specs are in my sig.
I run sunoco 94
Old 02-27-2007, 06:50 PM
ls1408cp's Avatar
12:1 93octane
Old 02-27-2007, 07:32 PM
BLKWS6's Avatar
12:1 on 93 here in GA on my old FMS 408.
Old 03-01-2007, 11:36 PM
Chicago Crew UnderBoss's Avatar
I agre 11:25 to 11:5 at the most would be optimal for power and reliability on good 93 octane pump gas like BP on a N/A application!
Quick Reply: Best compression for 408.
