????L92 block and 427
Whats the diffrence between the LS7 block and the l92 block Any dissadvatage since there is a $1500 diffrence .
Or is it safe to go with the l92 418 . the price form TSP is the same so why not go with the bigger cubes
Hopefully someone with more info can post up.
I think the LS7 block is designed to be stronger as it was built for racing use. The L92 block was designed for production vehicles. I think the L92 should be fine for most folks. If your going to constantly turn it to 7K+ rpm in a LeMan type track, then go with the LS7 block.
Oh yea, I think the L92 uses a different deck angle so LS1 based heads won't fit. The LS7 uses the standard LS1 angles and heads.
Im running L92 heads on an LSX 427. They flow just fine.
Not to bash the setup its good for the money and I know the flow # are there but the powers not, in the 2 motors that I put together at my job (408w/L92/l76 ) I have seen the same #'s from an ls2 with TFS heads . Obviously the big motor made more down low .
What where your Dyno #'s and track times
