Will my 6.0 internals work in an LS3 block?
Ive tried searching and there is so much BS that it got me nowhere. Im getting an SS with an iron 6.0 in it thats bored .080. I think it might have split a cylender wall because of the extreme over bore. Something is causing white smoke from the driver side exhaust. Im prepairing for the worst and researching my options. Can I buy a bare LS3 block, bore it to 4.080" so I can use my pistons and bolt all my current 6.0 parts into the block? Thanks very much in advance for your help.
Jeremy
Jeremy
why get a LS3 block when you can spend 400 bucks more and get a LSX block and not worry about it and go as big as you want? or are you just wanting to go aluminum? and a .015 overbore shouldn't be that much problem with that block.
Jeremy
on scoggin dickeys they are 1399 for the 6.2L aluminum Bare block. but seriously I doubt your going to have problems with .015 I mean most blocks come at like 3.995 you have to hone out the extra .005 so realisticly .010
Jeremy
Jeremy
think his name is Shirl Dickey. I believe that you can go at least 0.020 and
still be safe. I know that the sleeves are cast in the block so depending on
how true they're casted (not centered) is the final factor in boring.
You might check with one of the sponsors for additional info.
I am emptying my 383 internals and putting my Darts on a 4.070 block, i am using Mahle pistons which come with rings and pins, they arnt a great deal of money. From what i can gather all i need is new lifter trays and gaskets to do the swap. I am using an aftermarket ECU and external crank trigger though, i'm also renewing the kifters for new LS7 ones while at it.
