LS2 heads on LS1
LS2 heads on LS1
is there any porting/polishing i can do as an amateur to get the most out of these heads? i know you don't want to try an all out port and polish job unless you know what you're doing. also what about milling? setup will be ls2 heads, pac springs, and fm14 cam. thanks!
LS1 Tech Administrator
The LS2 heads are basically the same 243 heads that almost every CNC shop is using as a foundation for LS1 high flow heads. In stock form, they're worth 20-25 rwhp over an LS1 head. With hand porting and milling, you can pick up another 10-20 rwhp depending on your skill level. Although they respond well to porting, they're actually quite good in stock form.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
If your skill level is 0, your best advice would be to mill them some to raise compression and leave them unported. Porting in the wrong direction can hurt more than help. Most of the flow gains are in the valve job and throat/bowl area and requires special tools. Hogging out the port runner will hurt more than help.
__________________
that's what i figured. how much can i mill if i'm going w/ ls2 heads, fm14 cam, and pac 1218 springs? and does it matter/ do you recommend certain head gaskets? thanks for your knowledge
I have a set of 243's (LS2) heads just laying around with valves after I installed L92 heads.
Any idea if they have any value too anyone doing mods to their heads so as to have them all built till tear down time for less down time. Low miles less then 8k on them. Not trying to jack the thread just save someone down time on a head build. LOL
