rear main seal help
rear main seal help
i built a forged stroked ls3 for my blown 05 vette. problem is rear main seal is leaking(second time). i have the complete gm j tool kit for these motors so i am using the rear cover install tool and the rear main seal installer tool as well. i thought i had it fixed as it started and ran with no leaks but when we came back from eating to finish it up there was a little puddle on the floor. so i started it agian and it was dripping of course.....sounded bad *** though...open lg headers...lol... any way is there a trick or somthing to this
what crank are you using?
I have heard of a few Eagle cranks having issues with the rear crank plug (auto install) I think "Padre" on LS1GTO had his out 3 or 4 times with oil leak issues....
Man those seals work really well, I don't even use the tool to install. I wonder if the crank plug is bad. There is a plug inside the crank on the factory crank, don't know about the aftermarket strokers.
Moderator
Then again, he may just need to put a little silicone around the seal before he installs it in the rear cover.
gm has revised the rear main seal so the lip leans towards the clutch...i assume so people with out the proper tool can install with out issues. i have a blower and oil was getting past the seal. so we put it out backwards...with the lip leaning towards the crank and no leaks...as per codexxxx mentioned trying on here
