Ls7 dry sump on Ls3
Yes the LS7 crank is what you ned if you want to run the LS7 stuff. If you aren't using the LS7 crank and rods you will need to get an aftermarket crank like the callies or Eagle etc.
Yes the LS7 style crank is no different besides the longer snout to drive the extra long oil pump. Of course the stock one has a 58 tooth reluctor on it so you would have to get your crank for whatever computer you have.
Thank you,
So what I need to do the conversion is:
LS7 Crank
LS7 rods
LS7 Sump
Ls7 Oil pump
Ls7 front cover [whats that?]
LS7 balancer
The ls3 comes with 58 reluctor so thats OK
Is that it??
LS7 Crank
LS7 rods
LS7 Sump
Ls7 Oil pump
LS7 balancer
Is that it??
Not a true dry sump. More of a damp sump.
Guys with true HP LS7s not street vettes have put in the ARE pan and LPE tank. Or those building a 402 or 427 road race motors use the Daily dry sump, but that adds 6-7K to the build cost
The LS7 crank is not set up to balance heavier rods and pistons. This may sound minor but trying to get enough weight into the crank has been dicey. The ti rods are light and the pistons have a odd pin size.
The second oil pump (return to tank ) on the crank is not comparable to a real dry sump setup. No substantial vacuum created.
In the end may not consider this worth the noted weak dry sump benefit.
You could alternatively and easily run an Accusump http://www.accusump.com/ with likely better oiling insurance.
OWN3D BY MY PROF!
I know this is an old thread, but this is pretty much what I'm doing with my 408 build. I have the crank, timing cover, oil pump, pickup, and oil pan. I'm still thinking about getting one of those ARE pans and have them send me a tank and lines at the same time.
Here's a thread that pretty much covers exactly what you need to use the LS7 dry sump setup:
https://ls1tech.com/forums/generatio...-pump-ls1.html
