Strange Dana 60 interest?
There is another thread that isn't going anywhere but I didn't feel that it would be right to post in there because another vendor was mentioned in the first post.
What kind of interest would there be for a Strange Dana 60 rear?
PRSF05 Strange Dana S60 '98-02 F-Body Camaro/Firebird (regular retail is usually $2289.99). We can get this down a little more for 5 or more orders.
The Dana S60 features -
35 spline axles
HD Posi
Chrome Cover
3 or 4 channel ABS
The 1993-97 rears have built in mounts. The 1998-02 require you to use your factory brake backing plates. They can be sent into Strange before the rear is built. The stock driveshaft will need to be shortened by 1.625".
The following gear ratios are available - 3.54, 3.73, 4.10, 4.30, 4.56, 4.88, 5.87.
The weight difference between Dana 60 and 12 bolt is 20-25 lbs, the Dana is heavier. Dana rear is fully assmebled with posi weights around 215 lbs and 12 bolt is around 189 lbs (weight with brakes). The weight difference between 12 bolt and 9" is about 12-15 lbs the 12 bolt being lighter.
Ring gear sizes:
12 bolts ring gear only 8.875 OD
9 ring gear is is 9" OD
Dana has ring gear of 9.75 OD which is alot stornger than 12 bolt & 9".
The standard Dana gear (not Pro) can withstand close to 1200 RWHP.
The True-Track is posi is standard along with Power-Lock. These are good for about 600rwhp. The Dana's posi is alot stronger than a 12 bolt and the 9". This is because the Dana Posi's are 35 spline, 12 bolt is 33 spline and the 9" is a 33 spline.
35 spline axles
HD Posi
Chrome Cover
3 or 4 channel ABS
Ring gear sizes:
GP posted - https://ls1tech.com/forums/sponsor-group-purchases/568957-strange-12-bolt-dana-s60-rearend-group-purchase.html and on our website.
Originally Posted by tbyrne
5 orders are in so the GP is now a GO!
Tom,
What's one gonna cost me to my door or wherever it would have to be shipped at in zip 29456? Actually, I think I can get it shipped to the wharehouse here at work at 29445.
Jeff
Not sure which one your looking or but the rears are shipped freight collect so we won't have an exact quote. They are usually between $125. and $250.
Seeing that the GP minimum has been met, we're going to extend this pricing through Friday, September 29th.
I'm looking at the Dana S60.
The S60 is -
PRSF05 Strange Dana S60 $2049.99
The rears are shipped freight collect so you can take care of that with the driver when he delivers. The trucking company would call a few days ahead to set up the delivery with you and provide the shipping total. Most are usually in the $125. - $250. range.
