Holden Performance Australian LS1 Powered Vehicles
Every Tech should have this LS Timing cover Alignment Tool!
Old 06-27-2013, 06:57 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default Every Tech should have this LS Timing cover Alignment Tool!
AlignIt Tools are to designed to align the Timing Cover & Rear Main Cover and install the Seals on all LS base engines. :thumbs:
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 Timing and Rear Main cover and seals. Works with all LS based engines!
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Buy more than one of the AlignIt Tools and save!
http://www.saccitycorvette.com/AlignItTools.html
Here is a video that shows how simple it is to use. Tools used in videos are prototypes. The tools we sell are much nicer!:thumbs:
Installation with Oil Pan off.
Here is a Video the shows installation of Rear Main cover and seal with the Oil Pan on.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 11-17-2014, 06:36 PM
biker6151's Avatar
Default rear main seal pan on 5.3 chev
I have taken the rear main seal pan off and bought the new seal and the gasket for the rear main seal pan, but not the gasket that seals off between the top of the oil pan to the bottom of the rear main seal pan. Do I have to buy a oil pan gasket set???
Today I ordered the aliment/install tool, hope to get it in a few days.
Originally Posted by saccitycorvette
AlignIt is a LS Timing Cover & Rear Main Cover Alignment Tool and Seal Installer!
easy work of installing your LS1-2-3-6-7-9 Timing and Rear Main cover and seals.
Timing Cover AlignIt Only $26.95
Rear Main AlignIt Only $37.95
Timing and Rear Main AlignIt Kit Save 10% Only $58.41
http://www.saccitycorvette.com/Timin...nmenttool.html
SacCityCorvette LS1 2 3 6 7 timing cover tool. - YouTube
AlignIt Rear Main Cover Tool - YouTube
AlignIt Rear Main Tool. Only $37.95
Front & Rear AlignIt Kit. Save 10% Only $58.41
Old 11-17-2014, 11:03 PM
LS1Tech Sponsor
Thank you for your business, Biker!
You should be able to just apply sealant in the corners where the Rear Main cover and oil pan meet. Then use the AlignIt tool and snug everything down and then install the seal like the video shows.
Christian
__________________
Old 11-18-2014, 12:54 PM
biker6151's Avatar
Ok, but there is no gasket on the top of the oil pan where the bottom of the rear main seal pan mates to the top of the oil pan. Looks like the gasket that comes in a pan gasket set is (just guessing)about 1/64th of a inch thick. I guess enough gasket maker (permatex) would work, just wanting to make sure I won't have any leaks. Thinking about making a gasket to fit.
Old 11-25-2014, 05:39 PM
LS1Tech Sponsor
Sorry for late reply. where the oil pan gasket and the rear main cover gasket meet is where the sealant goes..
Christian
__________________
Old 12-20-2014, 07:23 PM
compton-z28's Avatar
now this is pretty slick here
Old 01-14-2015, 11:22 AM
LS1Tech Sponsor
Same Day Shipping!
__________________
Old 01-17-2017, 08:42 PM
jomart95's Avatar
Just bought mine! Along with the aluminum barbell. Great product, great idea...can't wait to use them! Thanks!
Old 01-20-2019, 03:11 AM
cmysix's Avatar
SAC CITY CORVETTE has some well thought out inexpensive products that work! Electrical kit for the C6 wonderful my voltage NEVER drops now!
Quick Reply: Every Tech should have this LS Timing cover Alignment Tool!
