milling l92s
Stock L92 combustion chambers are 68.4cc +-1.0
.030 off would make them 62cc roughly.
There are other things like like the piston over the deck, headgasket diameter, head gasket thickness etc. that go into the equation. Not every one is the same. I cc'd my heads and they came out to 62cc's, .045 cometic headgasket, piston up .010, stock lq4 pistone have a 6.7cc dish also.
Good idea: check p2v clearance with a used head gasket (if you're using the same gasket type - to simulate compressed state) using putty or something. Slowly turn the engine over to make sure. I believe that .600 lift will work with stock L92 heads (I BELIEVE!!! DON'T TAKE MY WORD AND F%*$ UP YOUR MOTOR!!!).
-TW
Agreed. There's a lot more going on than just head cc's. And the factory heads will differ by a little bit - it's best to measure before and after doing any milling.
-TW
-TW
I just finished my first 6.0 build with L92's. Flat top Mahle pistons which have valve reliefs cut into the pistons. I had .025 milled off the L92's. Running GM .051 thick MLS head gaskets. TSP cam, I'm at work so I don't have the exact spec's for the cam, I think its .598 intake/ .603 exhaust lift. No PTV issues.
