nitrous ?'s
Assuming all of the safety equipment, running colder plugs, fuel pump, tune, etc. etc. a 150 shot wet would be about the most you would want to run on the stock block. Could always play it a little safer and spray a 125 shot which is probaly what I personally would do but there are many people spraying 150 with zero issues.
In terms of cams...at that level of spray running a custom grind n20 cam or an off-the shelf with a wide lobe separation is not going to really benefit you at all over just any old off-the shelf. If the car is going to be sprayed constantly and/or with a bigger hit as in 200/250+ then yes.
i had a custom advance induction cam thanks to MY DUDE " STEALTHFORMULA " i was running a 150 all day atleast 80+ runs no problem till i jumped to 175 that lasted about 15-20runs lol............bye bye rings
The n2o limit for stock motors would be a 150 shot. After that things really get interesting.
As for a cam, if you look at the gains your going to get from the juice its going to be more tq than hp. So finding a cam that will make more hp than tq is going to be you best bet. Many people go with a blower came as they are pretty similar. Another one would be the cc306 on 112.
i was asking how much stock long block could handle spray wise. but i was also wondering what cam would work well with the spray yet make decent powere on motor to.
