cracked rotors
Old 10-22-2008, 10:53 PM
zachness's Avatar
Default cracked rotors
cracked rotors the end of the world? The cars low and when they get hot and water hits them obviously they crack. If i baby em should it be fine?
Old 10-22-2008, 11:10 PM
z28bryan's Avatar
Would you mind telling us what brand rotors you have, drilled slotted, etc?
Old 10-22-2008, 11:52 PM
SS1875's Avatar
Replace them...best answer I can give you.
Old 10-23-2008, 12:07 AM
wabmorgan's Avatar
MAy not be the "end of the world" but MUST be a damn close 2nd.
As all ready suggested... I'd replace them ASAP!!!!!!!!!
Old 10-23-2008, 03:10 AM
Tom's_03SVT's Avatar
you can get a decent set off Ebay fairly cheap.
Old 10-23-2008, 05:59 AM
FLSSLS1's Avatar
I bought Baers (cross drilled and slotted) and one of the reasons was that they are gauranteed agaist warping and cracking for 3 years.
Old 10-23-2008, 08:57 AM
z28bryan's Avatar
Still don't know what kind of rotors the original poster has.
Old 10-23-2008, 11:14 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Just a quick reply, being lowered doesn't make the rotors any closer to the ground. Avoid cross drilled and slotted as the slotted rotors just eat pads quicker, and the cross drilled just cause weakness in the rotor. Watching Martinsville last weekend, they did a whole 20 minute segment on brakes and they said that the only reason they ever drilled a rotor was to reduce weight, but it came at a cost of cracking and eating up pads.
Stick with a solid rotor from a good name and bed them in properly and you'll be fine.
Old 10-23-2008, 11:17 AM
LS1TECH Sponsor
Sam Strano's Avatar
Are you kidding me? We are talking about brakes here, kind of a good thing to not risk failing..... Cracks are *BAD*. Think about how much power the car makes (a lot), and how long/far it takes to get to 60 mph. You stop from 60 in less time than it takes to accelerate to it. How much energy is being put through the brakes? What happens when a rotor breaks???????
If cost is an issue I have rotors that aren't junk for $45 each. I also have Brembo and ATE's up the scale. We even have a few rotors kits that give a bit of a discount for buying all 4 on the Brembo and ATE's.
__________________
Old 10-23-2008, 11:18 AM
LS1TECH Sponsor
Sam Strano's Avatar
All the above statements are right on the money.
__________________
Quick Reply: cracked rotors
