Forced Induction Cam
Old 10-25-2008, 01:22 PM
cbr600rx7's Avatar
Default Forced Induction Cam
This is a going to be on a TTI 60 trim LS1. Other then a few supporting mods injectors, fuel pump, tuning, and meth injection the engine is stock. My question is what are good specs for for a mildly aggressive forced induction cam. Also along with valve springs i would like to keep the valve chatter to a minimal so if i would like to keep factory style rockers.
Old 10-25-2008, 01:27 PM
calongo_SS's Avatar
LS6 cam and 918 springs.
Old 10-25-2008, 01:31 PM
Dark Shadow's Avatar
alot of people run this or around it including my self.
http://www.exoticperformanceplus.com....html?item=679
232/240 Lift .595/.608 LSA-115.0
Old 10-25-2008, 03:50 PM
BlackySS13's Avatar
LS6 here.
Old 10-25-2008, 04:16 PM
MY99TAWS6's Avatar
Lingenfelter gt7. You can look up specs on lingenfelter site. Very close to 05 z06 cam in specs. I also am using 1.8 rockers with it and before any jumps and says you can't it says you can right on the cam card I have seen.
So that brings it up a bit but it should be plenty mellow in terms of lope. Lingenfelter uses it in most all their turbo builds and they build some pretty fast cars.
Now haven't actually had my car running with it yet just finishing up the build next day or so.
That other one from exotic sounds ok too. There are many many opinions on what is the best turbo cams.Seems people argue over reverse split, normal split how much split.how much lift ,what lsa. Turbo is going to work pretty good no matter what type of cam.
Think it depends more on what you want.I wanted something not too wild. Figure car is going to have more power than I can ever use especially on the street.
I wanted not much lope at all ,easy to tune and not that much lift so wouldn't have to change out springs every 20,000 miles.
Old 10-25-2008, 10:54 PM
quicksilverado's Avatar
With that setup I would stick with the stocker and upgrade the springs. It is capable of supporting more power than a stock motor can handle.
Old 10-25-2008, 11:00 PM
shawn_c992001's Avatar
EPP Forced Induction cam and dual valve springs.
Old 10-26-2008, 12:39 AM
tomz28's Avatar
i run a 04 ZO6 cam with duals
Old 10-27-2008, 11:09 AM
cbr600rx7's Avatar
For the guys running the EPP on the street how does it fair. I understand its a little aggressive side and my car is by no means a daily driver however she does see short drives to and from the track.
Old 10-27-2008, 12:50 PM
98Z28MASS's Avatar
Lingenfelter GT2-3, any of the speed inc turbo grind cams (vary in size so you can pick your aggressiveness)
Old 10-27-2008, 02:24 PM
618HAWK's Avatar
Daily driver for me with no problems, very happy. Average 80-100 miles a day and still enjoy driving the car.
Old 10-27-2008, 08:12 PM
cookba's Avatar
618HAWK, what size engine are you running this cam in? i am also researching cams for a FI build and really like the EPP cam. how daily drivable is it? and what are you seeing MPG wise?
Old 10-27-2008, 09:05 PM
618HAWK's Avatar
It is a 347, no problems with drivability drives like stock, The wife drives it with no complaints, if that says anything. A good tune is a must for that though.
As for MPG I have not really checked, (way gas prices keep dropping I have not filled the tank yet), in town I think it is close 15-17. I have a hard time keeping my foot out it.
Old 10-27-2008, 09:25 PM
DanWS6's Avatar
Driving it the way it was meant to be driven is a good thing.
My cam is slightly larger than the EPP cam and I get 17mpg on the highway if I stay out of boost. Which I never do so I usually get 13-15mpg per tank.
Old 10-27-2008, 09:48 PM
ninetres's Avatar
I got a big *** high lift reverse split. Go big or go home.
Old 10-27-2008, 10:44 PM
crashly's Avatar
LOL
me too
27x / 26x @ 116 sep
358 cubes
just get a professional to get it for you
Old 10-27-2008, 11:38 PM
ninetres's Avatar
Originally Posted by crashly
LOL
me too
27x / 26x @ 116 sep
358 cubes
Damn. Makes mine look weeny
Old 10-28-2008, 01:04 AM
crashly's Avatar
yeeh,
its a bit hard to control the engine with that cam....
actually put a smaller one in,
not sooo angry..
went back to a straight up 258/258 @ 114
on regional tracks , the car blows the tyres off with big cam
34.5 - 17 -16 tyres
ash
Old 10-28-2008, 08:22 AM
jmdgto's Avatar
i have the epp cam. still 25mpg on highway, was a dd . it is good on the street.
Old 10-28-2008, 11:39 AM
cbr600rx7's Avatar
My mechanic thinks the EPP will be too hefty for the 60 trim?
Quick Reply: Forced Induction Cam
