Anyone info on the new GMPP LSX-DR heads?
Old 10-27-2008, 02:42 PM
Hans Grüber's Avatar
Default Anyone info on the new GMPP LSX-DR heads?
I can't seem to find any info on these, such as what port sizes it uses.
http://gm.wieck.com/forms/gm/previewpage?049517
http://gm.wieck.com/forms/gm/previewpage?049520
The LSX-DR Cylinder Head is designed for 4.125-inch-and-larger cylinder bores. Airflow can reach 430cfm on the intake side and 280+ cfm on the exhaust ports.
The all-new LSX 454 crate engine uses LSX forged rotating parts and a newly developed 0.635-inch-lift hydraulic roller cam, making this a monster LS engine in a classic cubic-inch combo. Through its four-barrel carburetor, it's rated at 620 horsepower.
Old 10-27-2008, 03:51 PM
Jontall's Avatar
Sweet...
Old 10-27-2008, 05:34 PM
LSX-PWR's Avatar
I second that. Sweet...........
Old 10-27-2008, 05:45 PM
Haans249's Avatar
Are these supposed to be LS7 ports? What rocker arms are they using with those raised valvecovers? Can you get those valvecovers seperate? Those are badass.
Old 10-27-2008, 10:12 PM
NemeSS's Avatar
from the chmber deck side they almost look like bbc heads,
and it looks like they have oval ports like bbc too. not rectangle
Old 10-27-2008, 10:29 PM
The ports are rectangular:
http://gm.wieck.com/forms/gm/previewpage?049513
No idea if they are LS7, LS3 or some other style
http://gm.wieck.com/forms/gm/*query?...rce=all&page=1
Those exhaust ports look like NASCAR SB2, R0x and R07 ports, simply huge!
Old 10-27-2008, 10:57 PM
magic's Avatar
Looking at the bolt pattern on the cylinder heads, it looks like LS7...LS3 the intake bolt pattern is a little lower. However, I wouldnt be surprised if one had to use a dedicated intake manifold for these heads.
Old 10-28-2008, 02:00 PM
THEMADTYPH00N's Avatar
Is this stuff released yet?
Old 10-28-2008, 04:05 PM
Mikkofin's Avatar
When will the LSX 454 crate be released? Any ideas / predictions?
Anything on the expected pricing?
Thats interesting stuff right there if the price settless right.
Old 10-28-2008, 05:21 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Yeah, the exhaust ports look a lot like the ROX stuff.
Old 10-28-2008, 08:42 PM
KCS
Moderator
KCS's Avatar
Well, the intake ports on these DR heads are about 3/8" higher than C5R heads, so yeah it probably requires a specific manifold.
I hope it left material at the roof for a nice spring.
Old 10-28-2008, 09:31 PM
JPH
JPH's Avatar
I'm sure Robin L will jump in and chime in on this. Hes usually got the gmpp info.
Old 10-28-2008, 10:58 PM
njc.corp's Avatar
it looks good-like the rocket cover-s the exhaust flanges look different in the pictures-
i mean bolt pattern for the flange?
or is it my eye's?
Thanks
Old 10-29-2008, 04:27 AM
My guess is that GM accidentally posted this early and we'll get all of the official info when SEMA starts this Nov.
Old 10-29-2008, 04:34 AM
LS7 head:
http://gm.wieck.com/forms/gm/previewpage?022803
LSx-DR head:
Looks like the port location and manifold bolt holes are different.
Old 10-29-2008, 06:02 AM
njc.corp's Avatar
c5r intake pattern?
Old 10-29-2008, 09:27 AM
LS1Tech Sponsor
Robin L's Avatar
It's a revision of the C5R head.......but it really is different in a lot of ways.
The intake pattern is unique. The face angle is even different. The bolt pattern is wider (thank god)
The chamber is larger than a C5R. The C5R was developed for a small cubic inch road race application.
To give you an idea of the port height difference the new head needs a .400 long valve than a C5R that has been raised to the moon
It requires a shaft rocker system. Jesel has made mine and I think that others have made them also. My Jesels work great!
The flow numbers mentioned are right on with what I have seen on a bench that I trust. My old C5R heads on that same bench flowed in the 390-400 range.
I have not poured the ports for volume. The ones that I have are a tad small in the cross section. Really the proof is on the dyno and at the track.
Old 10-29-2008, 09:32 AM
LS1Tech Sponsor
Robin L's Avatar
Here is our old C5R port
Old 10-29-2008, 09:50 AM
OWN3D BY MY PROF!
Robin, can you talk pricing yet or when we'll see any sort of formal GM announcements refering to specifications, release dates, pricing, etc...?
Old 10-29-2008, 10:15 AM
LS1Tech Sponsor
Robin L's Avatar
I don't get invovled in pricing. What I don't know won't hurt me
The specs should be out soon if not at SEMA. The plastic models were displayed at SEMA and PRI last year. I have been HOUNDING my sources about a release data as well as the matching manifolds. They have not given me any indications when they will be available.
I wil be testing a set of heads and a manifold on the dyno in the next month. I should say if all the parts show up
Pricing will come from GMPP or the Dealers
Robin
Quick Reply: Anyone info on the new GMPP LSX-DR heads?
