Can LSx tuners tune other GM PCM's?
May be a silly question, but is there enough commonality among other GM PCM's that a tuner using LSx software (LS1Edit, HP Tuners, etc) could modify other GM PCM's?
Reason I ask - I have a 2003 Caddy SLS as a DD that is tossing EVAP codes (P0440 - large leak), scoured the whole system and can't find a clear leak, going to replace the purge solenoid and the fuel tank pressure sender next. But if I can't get it fixed by January, I'm going to fail OBD2. Would love to give my local LS1 tuner $100 to tune out the EVAP system, like they have the AIR system on my LS1, and be done with it.
Yessir, to no avail. That particular car did have a recall for the fuel tank pressure sensor, and I verified it was performed.
Its a 2003 SLS, 44k miles. I suppose it may still be covered under an emissions warranty, but does that cover EVAP? Kinda thought it only covered the cats.
Closely inspect the top of the fuel filler. I have been ordering about 3 a month for corrosion. They have been rusting out. The Purge solenoid won't set that DTC. The Vent Solenoid will. I have replace about 1 a year over the last 5 years. The Fuel Tank Pressure sensor will set this DTC also. It usually set more DTC's with it. I have replace a ton of these, but only a few in the last 2 years. This is easy to replace. You have a trap door in the trunk.
I would look at that Orginal Gas Cap for cracks in the sealing ring and the rust/bumps at the top of the filler.
I have a filler and cap to replace today.
Vent Valve is around the front of the LR control arm
If you need I can loan you a PCM Tuned that will pass emissions for you. No other Mods. You pay shipping both ways that is all.
I can send you the bin file if you would like?
Sorry I forgot about this.
Also this started to rear its head a few months ago. I would get the "Check Gas Cap" message intermittently. Then it would be present long enough to throw the SES, but after awhile the SES would dissappear for a week or so, and then start coming back. For about the past 3 months, its been there full time. Not sure if based on that you can offer any more advice on trouble-shooting. But appreciate you saving me the cost of a new purge solenoid!
Appreciate the offer, I'll keep you in mind if I haven't fixed it by January. Ideally I'd rather address the root cause, but if a bandage gets me through emissions I'll take it.
Apologies for getting into Caddy stuff on an LSx board, but in my years here, I've found Tech to have the best GM minds out there!
EDIT: Oh, is this AJ from the Caddy forums? Didn't realize that until after I posted.
Much appreciate the input. Ok sound like the vent solenoid might be a good start. I checked the filler neck, looked good, and tried a replacement gas cap. The car isn't too old ('03), nor has that many miles (44k). Last I checked and cleared the codes, I was only seeing 0440. Did pull the pump access panel in the trunk to take a gander. Actually if you have an EVAP schematic for that car, it would be a huge help. I don't have an FSM for this car, but looking at the FSM for my T/A, something looks amiss with the EVAP lines at the tank and fuel pump. There are 3 lines supposed to be going to the fuel pump assmebly - supply, return, and EVAP. The EVAP line in the center is apparently not connected. Not sure if it's supposed to be like that.
(1) Positive crankcase ventilation (PCV) Valve
(2) Secondary air injection (AIR) Shutoff Valve Bank 1
(3) AIR Vacuum Solenoid Valve
(4) Fuel Pressure Regulator
(5) Evaporative emission (EVAP) Purge Pipe to EVAP Canister
(6) EVAP Canister Purge Valve
(7) Throttle Body
(8) AIR Shut-off Valve Bank 2
(9) Intake Manifold
(1) EVAP Canister Purge Solenoid
(2) EVAP Canister
(3) Fuel Fill Neck/Fill Cap
(4) Rollover Valve/Fuel Tank Pressure (FTP) Sensor
(5) Fuel Tank
(6) EVAP Canister Vent Solenoid
(7) Vent Hose/Pipe
(8) EVAP Vapor Pipe
(9) EVAP Purge Pipe
(10) EVAP Service Port
Moderator
Can you tell by a tank pressure / leakdown
test or something, whether it's a true leak
or just a(nother) bad pressure sensor? Do
any pull-n-reseat on the connectors for the
tank sensors, etc.?
tank sensors, etc.?
Yes, tried reseating the pressure sensor connection, no luck. I know the FSM procedure specifies filling the line with N2 pressure and monitoring for leak. I can obtain some nitrogen if need be, I may give it a shot. Just ordered a vent solenoid from GMPartsdirect for $18. We'll see if that works.
AJ, thanks for the schematics. What I really could use is a picture showing the detail for the EVAP hose routing at the top of the gas tank, especially up to and including the fuel pump unit. Trying to make sense of the line routing, and why the middle of the 3 hose connections at the tank has nothing attached.
