Is the block surface clean enough?
Old 10-29-2008, 08:20 PM
scottHMT's Avatar
Default Is the block surface clean enough?
I used a razor, a scraper, and a dremel with a plastic wire brush. It feels smooth to the touch, just wondering if i should clean it more.
Old 10-29-2008, 08:57 PM
hirdlej's Avatar
lol no. keep going
Old 10-29-2008, 09:09 PM
LSX Mechanic
Damian's Avatar
Looks like you've got a tad more cleaning to do. I see some material left here and there. I would also bring each piston up to TDC and clean them. Would be a shame not to while the heads are off, and remove that carbon deposit.
Old 10-29-2008, 09:29 PM
scottHMT's Avatar
damn, any other tips on what to clean with? the razor just seems to be scraping the metal, and im afraid to use a wire brush, maybe a soft metal wire brush would work?
Old 10-29-2008, 10:01 PM
99345hp's Avatar
I like using a scrotchbrite pad on a air 90 grinder. Those little things work amazing for cleaning off old gasket material.
Old 10-29-2008, 10:07 PM
waterbug1999's Avatar
X2 ... Scotchbrite pad worked good for me as well, its not as rough as it looks either..... And clean them damn pistons while your at it.
Old 10-30-2008, 09:27 AM
mmorellicamaross's Avatar
were do you get those pads?
Old 10-30-2008, 10:08 AM
on2
on2's Avatar
uhhh wal mart. home depot. just about anywhere. lol
Old 10-30-2008, 10:27 AM
04600rr's Avatar
if you dont have a air grinder go get yourself a gasket scraper and use brake clean also. brake clean evaporates quickly and will eat the **** out of that old gasket material.
Old 10-30-2008, 11:31 AM
Pushead's Avatar
No, clean up that black stuff at the bottom of the surface, and clean the pistons at the same time.
Old 10-30-2008, 11:35 AM
thunderstruck507's Avatar
ditto, takes like 2 minutes to do the whole thing
Old 10-30-2008, 11:51 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
It's tough to remove the composite gasket material with a scraper sometimes, but like mentioned earlier, it comes off pretty easily with brake clener and a scotchbrite pad. I found a bag of the blue scotchbrites which are supposedly 'scratch free' that I use to clean some areas of the underhood and undercarriage with good success.
Old 10-30-2008, 12:05 PM
Blck_01ss's Avatar
Scotchbrite!!!!!!!!!
Quick Reply: Is the block surface clean enough?
