WIll my stock bottom end take any n20 with the mods i already have
Old 11-06-2008, 10:26 PM
cdaddy's Avatar
Default WIll my stock bottom end take any n20 with the mods i already have
Hey guys,,,I have a 99 ss camaro 6spd... I was wanting to put some spray on my car and was wondering if or what it could handle if any?? These are the mods I already have... My internals are stock but heres my list of stuff i have done....
Performance
241# LS1 Stage II Ported Heads w/ stock valves
Comp Cams 244/248 .598/.598 115
Comp Cams Titanium retainers
Comp Cams 918 Springs
Comp Cams 7.350 pushrods
FAST LSX 78mm Intake
LS6 Ported oil pump
Rollermaster double roller timing chain
2.5" Off Road X pipe w/ Flo Pro Twister mufflers and optional cutouts before the mufflers.
FLP long tubes
Whisper Lid
Smooth Bellow
Home Ported Throttle Body
!AIR (have most of the emissions equipment in a box as well)
!EGR
NGK TR55's
MSD Super Conductorslll
Please any info would help... I would like to go crazy with like a 150 shot or something but i just dont know if the stock block will take it or not... As of right now im putting down 444whp and 401pds of torque... Thanks
Old 11-07-2008, 05:32 AM
dawiz's Avatar
you will be fine with a 150 if you have the fuel to support it.
my c5 is similarly modded and makes the same na numbers your making. i am spraying nitro daves wet kit with a cell (110).
heres my dyno sheet.
https://ls1tech.com/forums/nitrous-oxide/1012991-nitro-daves-wet-plate-kit-dyno-numbers.html
Old 11-07-2008, 06:17 AM
Mike@HSW's Avatar
just like dawiz said, 150 will be fine as long as your fuel system can keep up and you have a good tune. My stock bottom end car puts down 496 rwhp and gets hit with a 200 shot. we have another customer with a similar setup like you, 445 rwhp and hes been spraying 275 for two years. Its all in the tune
Old 11-07-2008, 06:24 AM
jmill96Z's Avatar
Upgrade to a 255 pump and run a fuel pressure gauge. Like said above you should be able to hit it with a decent shot, but pump failure will def. kill the motor. Also you'll have to get some colder plugs
Old 11-07-2008, 08:42 AM
1 QUIK LS1's Avatar
275 on a stock bottom endwow thats good to know
Old 11-07-2008, 09:14 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
You might be surprised how many people are doing that and more
But they are willing to walk the tight rope.
Old 11-07-2008, 09:24 AM
Nick@HSW's Avatar
haha, its a lot easier to make decisions when you don't care about the bottom end isn't it.
Nick
Old 11-07-2008, 11:34 AM
Super Speed's Avatar
When I order my new motor I'm going to see how long it survives on the 200
Old 11-07-2008, 01:26 PM
pozesd99''s Avatar
why is your all motor cam a 115lsa??? thats my lsa on a turbo cam??
