what kind of power u guys making
Old 11-10-2008, 12:37 PM
svtkilr's Avatar
Default what kind of power u guys making
I have a 6 speed camaro and im planning on a built 6 liter bottom end nice blower cam ls6 intake not sure what heads yet and a tc78mm turbo I am lookin for about 850 whp and just wondering what heads and how much boost u guys are using to get that with a setup close to mine ive been told at that power level I could use stock untouched 6.0 heads and make that power at about 15 psi just lookin to see what route everyone else uses to make that power
Thanks
Old 11-10-2008, 12:39 PM
67Firebird455's Avatar
You can make that kind of power around that psi with that engine with those heads if the bottom is forged with that turbo. If it were me, I'd go with a slightly larger turbo, but that's just me. You doing a front mount, and meth or no meth?
Old 11-10-2008, 05:28 PM
svtkilr's Avatar
It will be a fully forged bottom end The reason I'm runnin that turbo is cause they say it spools faster... It is a front mount and No I'm not planning on running meth
Old 11-10-2008, 08:56 PM
svtkilr's Avatar
Anyone else...
Old 11-10-2008, 09:35 PM
black98ws6ta's Avatar
Rod and pistons, and crank it up. I am a believer in stock heads, lol.
Old 11-10-2008, 09:53 PM
svtkilr's Avatar
But do u guys thinks 850 is capable with stock heads with only 15 psi on pump gas
Sluggish's Avatar
I don't think you will be able to get 850rwhp @ 15lbs with stock 317s.
Old 11-10-2008, 10:00 PM
svtkilr's Avatar
What do u think I can get @ 15 psi...
Old 11-10-2008, 10:03 PM
y2khawk's Avatar
~700
that's where i was with a 346, 317's a weenie cam and 15psi.
Old 11-10-2008, 10:28 PM
svtkilr's Avatar
Originally Posted by y2khawk
~700
Was it stock 317's and was u on pump gas
Old 11-11-2008, 12:02 AM
svtkilr's Avatar
What route do u guys suggest on heads to make 850 rwhp if using stock style head I wanna stay under 20psi cause I hear that u start pushing water above 20 psi so I guess what I'm askin is can 850 be made and stay in a safe zone on pushin water with stock heads
Old 11-11-2008, 12:59 AM
You are looking at it all wrong, heads dont start to lift or "push water" at any certain psi or even horsepower level. I would put the best parts you can use based on your budet. If you do a larger motor, nice set of heads, and cam the car will make more power on less boost.
Reguardless of your motor size, heads, or cam if the tune and assembly is good the engine should not push water at 850rwhp through a 6 speed.
Old 11-11-2008, 04:04 AM
ohplz's Avatar
well man im trying to organise my build too, with not much info but gathering what i can..
so far im lookin at
ls1 + forged internals etc
PRC LS6 stage 2.5 CNC ported heads
224/228 custom turbo cam
gtk1000 ( turbonetics turbo )
and a few other things too and im hoping to get 16 - 20psi and 850 RWHP
( curently at 500 with what i have )
still researching but i think im getting close too all the answers
Old 11-11-2008, 04:30 AM
EPP
EPP's Avatar
Stock head deck thicknesses will limit boost to somewhere around 16 psi of boost as an average. I would go with AFR heads as they have a thicker deck surface and will allow you to run more boost. The additional flow from the AFR heads will help increase the horsepower without having to run as much boost as an added benefit.
Check out this build that we did. http://www.exoticperformanceplus.com...Car.php?car=39 This Firehawk would of made a lot more power if we could of cranked the boost up, but the 11.0/1 compression ratio and pump gas kept the boost down. Bob
Old 11-11-2008, 06:14 PM
svtkilr's Avatar
Well what route would u guys go to get 850 rwhp My thing is I don't want to spent the money on the more expensive heads if I can make it safely on a stock set of heads I don't mind running a mixture of race gas if I need to cause I don't intend to run that kind of power all the time I just plan to run on 650 to 700 most of the time but I wanna get 850 for My track tune but need to know if it will be possible to achieve that and still be safe ... What kind of boost will it take to make 850 with a mixture of race gas
Thanks
Old 11-11-2008, 09:24 PM
98Z28MASS's Avatar
If you run good forged internals, good sized turbo cam, and 317's with head studs you could hit 850 rwhp, however as stated above you would be nearing the limits of the stock heads. As Bob mentioned a great set of heads would be AFR 225s with their thicker deck or maybe even a set of TFS heads. Now when you say built 6 liter bottom end do you mean the 364 CI configuration or are you using a 6 liter block with a different CI combo? Also, aluminum or iron block?
Old 11-11-2008, 09:51 PM
svtkilr's Avatar
I mean a forged 364 I want to use the aluminum block cause that 80 pounds from the iron block just seems unnecessary at the power level I'm looking to make
Old 11-11-2008, 10:21 PM
ninetres's Avatar
That turbo will not make 850whp at only 15 psi with stock heads. NO WAY IMO. Buy AFR heads, and add boost until you reach your desired HP.
PS--Have you ever driven or rode in a 600whp turbo car? Just curious.
Old 11-11-2008, 10:33 PM
svtkilr's Avatar
What kind of power do U think it will make at 15 psi... No I've never rode In a 600 hp turbo car but I'm actually running nitrous on My stock block right now and I'm makin around 575... why do u ask
Old 11-11-2008, 10:43 PM
GT67METHV's Avatar
cuz 600 on the street is almost overkill...
as a dd it is compromised.
Quick Reply: what kind of power u guys making
