Burning Plug Wires
You can run the OTVC looms, i don't on mine, my wires are 10.2mm, i use the factory boot protectors & routed my wires so not to touch or come close too the tubes, the drivers side is pretty easy, the 2 PITA ones are 2-4 on the pass side, it is very tight in there, if you can wrap them in that heat wrap along the side of the block & use the factory metal boot protectors, you should be fine, you just need to get creative, but the easiest way is gettting the OTVC setup.
Some run them over the valve covers some use the spark plug boot covers. A buddy of mine has just ran them under and tied them together to avoid touching anything and he's had great luck. Me...I've gone through 2 sets of MSD because a couple of the wires were resting to close to my Macs. Not sure yet what I'm gonna do when I install my LPP's here soon. Find out when the time comes.
Definitely OTVC and looms, Get yourself a custom setup you can make yourself you can get Taylor wire in 35 foot rolls, then get the specific Opti ends from them and high temp plug boots from MSD. build them and you done.
Soxxpuppet, that setup looks very nice and clean... i was going to just heat wrap the wires but will prbly end up goin the OTVC route... didnt know it looked as clean as it does!! anyone know where I can get a set from? maybe a sponsor but damn soxxpuppet that setup looks nice nice as hell
http://store.summitracing.com/partde...0&autoview=sku
took alittle practice to learn how to do it but it worked out real well
thanks for the links... im kinda afarid of making my own though, since spark is kinda an important thing for a car to run right lol... does anyone know if there is a complete OTVC wire package out there?
I decided to just hope for the best and reuse my stock plug wires. I did buy some boot protectors and heat resistant tape from summit to wrap the wires in. Im hoping this will be ok... what do u guys think?
I made my own OTVC wires using MSD wire components and Made For You looms. I had never made a spark plug wire, and mine worked out OK.
