Wheel Repair (CCW)
Old 11-15-2008, 02:40 PM
2002 Trans Am's Avatar
Unhappy Wheel Repair (CCW)
Can I get this repaired, and if so how much? (Tire is fine)
Old 11-15-2008, 03:19 PM
twitchtwice's Avatar
not sure about that. it may be better to just get a new one. wow. what happened man?
Old 11-15-2008, 03:20 PM
stevensLS1's Avatar
WOW!! first off those things are dirty.
i would probably send these pictures to CCW and ask them personally if you havent already. good luck either way.
Old 11-15-2008, 03:21 PM
Yeah I know they're dirty, today I planned on taking them off for the winter and polishing them up.
Old 11-15-2008, 03:23 PM
Here is the story
I had my stock wheels on the rear and CCWs up front. I was heading home to put the stockers up front and put the CCWs away for the winter.
MY original Goodyear RSAs were pretty shot so I was also going to order a set of winter tires and use those for the rest of the winter.
Well it was raining and slick; while I was taking the exit ramp on the highway when the back end kicked out and the car was heading into a ditch so I turned the wheel the other way and did some 360s, hopped a curb, and continued sliding in mud.
I get out and check the car and the body is perfect but my CCW took one for the team
Overall I am extremely lucky, I could have ended up in a ditch, I could have hit another car as I spun across a few lanes, I could have done a lot more damage.
Old 11-15-2008, 04:17 PM
BlkBird2000's Avatar
Yea pretty lucky. I would leave the tire on the rim and save it. Hang that bitch on the wall or something. Buy a new rim and tire for next year.
Old 11-15-2008, 04:19 PM
I would, but that tire is $300 + s/h + mounting and balancing
Old 11-15-2008, 04:56 PM
Detoxx03's Avatar
I'm sorry for your loss.
Old 11-15-2008, 06:40 PM
2fast97Z's Avatar
the tire might look ok for now but to make an impact hard enough to do that to the ccw the tire will probably develop a bubble in a few days hence the tire being extremely unsafe.
Old 11-16-2008, 12:59 PM
2000_SS's Avatar
well, IMHO, as a welder, i would say that's an easy fix.
the only thing i can see doing, is dis-mounting the tire and having the damaged area built back up by an experienced tig welder. the only issue i could see is when if was sanded/buffed/polished back up, that are would have a milky or silver-ish color compared to the rest of the wheel. i don't know what an aluminum weld looks like smoothed out and polished....but either way, it should look better than a chunk missing completely.
Old 11-16-2008, 02:00 PM
Iron Head's Avatar
Easy fix if it were only an I-Forged.
Old 11-17-2008, 12:04 AM
DopeFedZ's Avatar
That should be an easy fix. A local place in town would probably charge less than $100.
Old 11-17-2008, 07:57 PM
raptorws6's Avatar
Ouch, hate to see that. At least its not that bad, and can be fixed.
Old 11-17-2008, 08:02 PM
Yup, not too bad at all. CCW contacted me back and said they can fix it....I'll be sending it down there in a few days.
Also ordered snow tires today....****
Quick Reply: Wheel Repair (CCW)
