M6 RPM X Speed Question.
First of all I always read in the Kill Stories Section, and people say from a roll at say like 55-60 mph put it in 2nd gear? my car would probably be at 5500 RPM if i did that, which would do nothing because its about redlined. My car goes about 30mph in 1st gear and its redlined, 2nd is about 55-60 and so on... Does this seem normal to you guys or....I have 3.42's also when im doing 60 6th im about 1400 rpm. Thanks!!
yea that seems totally normal to me. I have the pretty much the exact same car too. For a good roll I like to keep the rpm's at about 3500-4000 and a 60 roll would be a decent 3rd gear for me. The people that say to put it in second may not have a 3.42 gear
hmm thats strange ill have to take a closer look at my revs next year... i could drop it down into 2nd at those speeds but it wouldnt be the best for a race cause i would be shifting very soon IMO
I dont think my rearend would like that to much Achotrod 10 Bolt. Well i do use the stock tach and I read somewhere there like 400 RPM off? so 5500 would be 5100? Might of been BS though. I usually shift when my car seems to stop pulling. Oh and also instead of making another post...for some reason my car always makes a little grind when i nail 2nd, even with the clutch all the way in...would this be syncros?
Weird thing is though, my clutch does chatter quite a bit so maybe that is affecting it. Ive puttin on about 3k miles since i bought the car and when i bought it it just had new sycros put in it...$900 worth of labor in the tranny. So i hope its not a bad syncro Thanks for help so far~!!
I'll have to look into that, guy i bought it from said it has stock gears. I'm going to be putting 4:10's in soon so ill just hold off for a little bit. Thanks for the replys and help.
hmmm its really tough to say what kind of gear you hve in there... u may have the stock 3.42s and your tach may be off or it could be a 3.73 You can figure it out by rotating the driveshaft and watching the rear tires
